csjr
Gurus,
My speedo doesn't work any more. I've had it checked at a specialty gauge shop--all good. I replaced the original cable and inspected the T-case gear at the same time--all good. The speedo doesn't register properly and after a few minutes falls to zero and that's it. I'm thinking the T-case oil warms up and therefore causes slippage with the gear inside the T-case (not the one on the end of the speedo cable). Any way to fix this without dropping the case and doing surgery? If I do drop the case and do surgery, can anyone give me a head's up on what to look for and how to replace the internal speedo gear? If I leave the tranny and just pull the T-case, are there any bearings I need to worry about falling into the case when I seperate from the NP435, or is there just the spud shaft running through the adaptor? I put it all in the truck, but it's been so long now I can't remember. Any help would be greatly appreciated.
Chuck
Chuck
