Both tooth counts were available in Broncos I believe. At least both have been discussed before, but don't remember if they were both in Broncos, or just in the transfer cases in general.
Since Jefe had a 7, at least that's a good start. But what other mods have you done? Big tire size change, or gear change by any chance?
If they were both indeed found in Broncos, then which drive gear you had would have depended on what gear ratio and tire size options were chosen originally.
And with factory tire sizes having not been that much different I would not think, then I'd say the differential gear choice would have made the biggest difference.
Didn't someone (Viperwolf maybe?) post up a chart on not only which tire size vs driven gear, but also which drive gear to get there? I'll see if I can find it.
