speedo gear question
Phil76
Aransas Pass, TX
I'm getting very close to getting the Bronco on the road, and have a quick question about making sure I have the correct speedo gear in place. I am running 33 x 11.50 x15's with a C4/D20, 2.5" lift, and 4:11 gears. What color/teeth do I need to have for this setup? Thanks.
Viperwolf1
electron whisperer
You have no absolute way of knowing until you compare the indicated speed (speedo) with actual speed (GPS) and see what driven gear you have now.
P
Phil76
Aransas Pass, TX
I figured you'd have some wisdom for me. I'll do that. I had an issue recently the last time I ran the Bronco down to the mailbox. Doing what should have been 40 mph, or so, the speedo was only reading 10 mph. It goes back to 0 when stopped, so it is moving. Any thoughts as to what could cause this...something in the cable, or TC?
Viperwolf1
electron whisperer
Could be a few things. Loose rear output assembly in tcase, damaged cable, problem in speedo head.
Quick & Dirty
Sounds like a bigger issue than speedo tooth count. However;
You can do a good estimate of what driven gear you need if everything else is in good order.
Speedometers are calibrated to 1000 rpm = 60 mph
Look up the revs/mile for the tires you have. The only 33x11.5 tire I found was the Thornbird which is 638 revs/mile. Multiply by gear ratio.
638 x 4.11 = 2622 rpm at 60mph (1 mile per minute)
So you need a gear ratio of 2.62 to get 1000 rpm at the speedo.
7 tooth is the most common drive gear, so 2.62 x 7 = 18.35
An 18 tooth driven gear will get you close.
