Speedometer Reading
67-TD
San Antonio, TX
I bought a used Speedometer from ebay. I hooked it up and it reads 10-20 mph over. Why wouldn't it read the same as my old speedometer. The only reason I replaced it was that my odometer and temp gauge didn't work in my old one. Thanks
Past_Miner
There is a torsion spring on the back of the speedo face that can affect how fast the cable must spin before the needle will move. The spring is there to return the needle to zero and counteract the magnetic force that actually drives these speedometers. An adjustment to this spring will cause a noticable difference to how hard the needle returns to the peg. I'm not sure if it can adjust the speed reading that much or not, but you could try to tension it up a little.
BTW, this will be a trial and error thing. Be prepared to pull your cluster apart several times.
