Spindle Bearing & Seals?
CobraJetKid
Saratoga Springs
Started my JBG disc brake conversion today and ran into my first roadblock. I've got the new spindles, spindle bearngs, seals, and spacers and can't figure out exactly where or how they all go together. Does the small seal go in before the spindle bearing? Any help would be greatly appreciated.
broncodriver99
Glen Allen, VA
The bearing goes in first then the small v seal with the flat side to the bearing. The spacer goes against the axle flange with the beveled side against the axle flange. The big seal goes on with the thick part on the axle, the thinner lip faces the spindle.
englewoodcowboy
Lick Creek Restorations
Be sure to grease all of the seal surfaces after you install them, failure to do so often results in seal failure very fast. You can even put a thin coat of RTV for the big seal (only on its mating surface) that goes on the axle to help hold it in place.
CobraJetKid
CobraJetKid
Saratoga Springs
Well I think this answers my question. The V seal is the one I really couldn't figure out. Wasn't sure if it went in before or after the bearing. Thanks a ton. Hopefully get the passenger side of this done after work tomorrow. Think it might be about time to start a build thread.
