spray gun recommendations
bigbassbronco72
Boise
I'm about to paint my bronco and only have a 33 gallon craftsman air compressor rated 7.2cfm @ 40psi. Does anyone have any recommendations for a gun that would run on the cfm I have and that they have personally had good experience with? Thanks!
Brian
bk005
San Antonio
Are you going to paint in pieces or all at once. Cutting it really tight on CFM but I've heard some people try an lvlp gun from Eastwood. Next thing to look at Is is that compressor is going to get air hot so watch out for moisture in your lines. Good luck. I had same compressor and have painted small jobs with it. I still have it and run it tandom with my 60gal when I need more CFM.
B
bigbassbronco72
Boise
I hear ya, I wanted bigger but I'm in a rental and don't have the outlet for anything bigger. But yes I plan to break it up a little. I'll have my fenders, tailgate, top, grill, and doors all off so my plan was to do a few pieces at a time so that I don't overload the compressor and start getting a bad spray. I'll need to get a water seperator for sure. Thanks.
allenfahey
I'm afraid you will need a bigger air compressor even if you paint it in pieces. Spray guns use alot of air especially if you use the proper HVLP fittings on the hose ends. Many people think HVLP (high volume low pressure) guns use less air because the low pressure part of the name. That low pressure is measured at the cap with a special gauge which is about 10 psi. Conventional guns measure about 25-30 psi at the cap. If you paint it with low air pressure you will get alot of orange peel even with a good spray gun.
What color are you painting your Bronco? If you are painting it a high metallic or pearl I wouldn't paint it apart because of the likely possibility of a color match issue. Reason of a color match issue would be marginal air pressure and problems with the orientation coat (also called drop coat). Especially if you are a novice painter.
With a 33 gallon tank reserve I would at the very least buy, rent, borrow a 110V air compressor or even better buy a bigger one and wire it for a plug into it into the dryer circuit in the laundry room.
A decent gun for the money is a Devilbis GTI . It's not a SATA but for the money it's a great beginner gun. There are cheaper guns out there but if you use a cheap gun it will not atomize the paint as well and you will have orange peel.
B
bigbassbronco72
Boise
Thanks for all the info, I've painted a few planes in the AF but definitely still claim to be a beginner. If this were my house I would have rewired for more volts in the garage. What about if I used a conventional gun? I know I would have more over spray, but might be a better choice. I've always used hvlp so not sure how well they spray.
Im just painting it bahama blue. Nothing fancy so color match should be good still.
Definitely not wanting orange peel afterward or a bunch or dried up over spray from a conventional gun on top of my paint though.
Unaweep
Grand Junction CO
Also this:
Harbor Freight used to sell a good air-dryer for <$500 on sale ( I didn't check their website, but I bought it last year on sale for $350). You still need the air to be 100f or below for ANY air-dryer to work properly, for your painting or a plasma cutter.
J.E.
B
bigbassbronco72
Boise
Thanks everyone. I found a few guns at Eastwood as bk005 suggested. They are full size guns and run on 4cfm with good reviews so I may go with it. Hopefully I get good results. Just need an air filter system for the tank.
rjrobin2002
rjrobin2002
If you spray in the morning when your compressor is cool, you can use a pair or disposable in line air filters one at the beginning of your flexible line and another at the gun and very good results. Dont try to spray in the evening after a day of sanding or airing up tires, you will be blowing water out of the gun.
allenfahey
Good luck with the gun, I'd seriously like to try it out. 4cfm's sounds too good to be true. Most HVLP guns cheap or expensive ones run in the 11-14 CFM range. I would recommend whichever gun you wind up getting to get a 1.3 or 1.4 tip. That is a good all around tip sizes for sealer, base (urethane or water), and clear. For primer 3M has a great 1.7 primer gun for around $100 that uses disposable (25 uses) caps and their easy to clean/use PPS cup system.
As rjrobin2002 stated, paint in the morning. Not only because it tends to be cooler but there are less/no bugs flying around. If you use HVLP fittings and a 3/8" or larger ID hose it will help tremendously with the water. The water in the compressor system is there because of heat and friction of the air going thru the piston and the lines. With the "A" and "M" style fittings that most people use at home are very restrictive and starve the gun and cause unnecessary friction in the line. Before I bought a Devilbiss desiccant filter system and I painted at home I would put a big "U" in the black pipe with a water spigot on the bottom of the "U". I would leave the spigot barely open to help with the water. If your compressor is barely adequate you probably can't spare the leak. If you use a larger compressor it will not cycle on and off and run constantly like the compressor you currently have. If it runs too much it will heat up and cause more moisture in the line. You are in Texas and tend to have less humidity than where I live here in Maryland and that will help too.
You would be surprised to see the difference what a little bit of moisture will do to the paint job. At work we have a rotary compressor and I have never seen a drop of water in the line in 4 years I've been there. When we switched to waterbourne, the paint company came in and measured the humidity in the line which was only 14%! They recommended an expensive RTI drying system and I told them they were crazy. 14% humidity was next to nothing compared to what I've seen in lines before. They had me paint half of an old hood black and clear it. They then installed a temporary RTI system and I painted the other side of the hood. There was a huge difference in the look of the two. The first one was less vibrant and clear looking compared to the RTI filtered side. I know you aren't going to go thru that expense but just want you to be aware of what moisture in the air line will do to the paint. Everything you do to eliminate it will help.
AZ73
I can't agree with Allen more about moisture. Even in dry AZ when I ran my new compressor, I was getting water out the end. I added about 70 feet of 1/2 in copper line to "cool" the air and condense the water at the bottoms of the "U"s, then a final Desiccant dryer at the end. Water is an issue you can control where a little effort goes a long way. At a minimum put one of these on your compressor:
http://www.harborfreight.com/38-in-air-filter-with-regulator-68232.html#.UyaARl6KmHk
and one of these on your line just before the gun:
http://www.harborfreight.com/disposable-inline-moisture-filter-68224.html#.UyZ_uV6KmHk
I used a 20 gal Craftsman with these 2 items many times on paint jobs when I was younger. Worked great.
