I used Second Skin on my Mustang and it was a remarkable transformation. Foil backed insulation and then the heat shield which is a thin, closed cell foam. My Mustang is like a Caddy inside.
Yeah, Paul....check post #15 in this thread. It's an option.You could always make your own too. Not sure if it works as efficiently, but you could probably add ceramic beads to just about any sound damping liquid and maybe kill two birds with one stone.
Don’t know that for a fact, of course. But I do believe several members here have created their own thermal barrier using standalone ceramic beads stirred into the liquid.
Thanks. Didn’t even notice the link on my phone. But now there is the “ahh, now I see it” moment.The Amazon hyperlink goes to the product to add to your liquid deadener of choice.
I should walk you through a new car and what is done and why. Are they chasing low frequency noises, or high frequency. Transmitted through a part, or is it coming through a hole? A lot of new cars have laminated side windows now, strictly for acoustic reasons. There are even special acoustic glass that is sometimes only used on the upper trim levels. The NVH department even has a calibrated hammer. it has a sensor to measure how hard you hit a part when checking for resonances. There is a science, as well as an art, and a fair bit of trial and error.I had a black '91 Square body Suburban that the headliner was failing on. Pulled it and sent out to an upholstery shop to have that fixed. While I had those two massive head liner panels out I added full coverage Reflectix to the underside of the roof skin. Goal was more thermal insulation as on really hot days you could feel the heat coming thru the roof. On the next trip what amazed me was how much quieter it was inside. Prior to adding it talking between the front and back seats was difficult. After adding it you could have a normal conversation. Really surprised me that some that flimsy and light could have that much noise reduction.
In the 4rnnr I added some amazon sourced mass loading stuff similar to Dynamat to the rear 1/4's. That helped with the noise. I put a layer of a self-adhesive thin insulating foam from Lowe's over it ("Frostie", something like that) and I can't say that it made much difference.
I know of one guy who lucked onto a sale of Ensolite back-packing sleeping pads. He used those for thermal insulation inside his doors and maybe other places as well. Some 3M Super 90 will stick that stuff where ever you might want it. Maybe keep an eye on Overstock or Sierra Trading Post for a sale on that stuff?
A friend has done the two different LizardSkin products on his Scout 800, but it's till a WIP so no idea how well it works. Looks good. He put it on the bottom of the floor and the engine side of the firewall.
A point got driven home a while back. Recall that most cars come with some sort of insulation pad on the underside of the hood that is now MIA? I've seen a couple guys put Dynamat type material on the underside of their hoods and report back that the noise reduction was significant.
