SS headers
1970mule
Hey does anyone know who makes some stainless steel long tube headers with the O2 bungs already welded in. I don't have the time/equipment/or patience to do it. any help is appreciated. also will they really resist corrosion? or will the heat break down the metal after awhile and cause problems? sorry for the dumb questions.
68rockcrawler
Wild Horses. I am not sure how they hold up over time as I have only had mine for a couple of months.
Amac70
ME
I don't think anyone makes a long tube ss header. wh does shortys with bungs, good header, don't expect the color to stay stainless mine where a rusty brown color in about two months. They are holding up just fine though don't think they are actually rusting.
68rockcrawler
I didn't notice he was looking for long tube headers. Sorry about confusing things! My WH headers are the shorties.
WorkerBee
Northern CA
The bungs are about $5 per pair on summit and any muffler shop could weld them in if you bought a regular set of long tubes. The majority of "stainless" used on muffler systems and headers is 409 which is only a few steps above mild steel. It'll resist rust and corrosion but only a small amount. 400 series is still ferrous meaning it has iron in it (magnetic). If you found a set of any 300 series stainless that would be different however the price would go up substantially. You're best bet for cost versus corrosion resistance is probably the ceramic coating. Others may have more comments about that though.
As previously mentioned, don't expect the stainless to stay perfect and shinny for long, that is of course unless it's 300 series, then you can just expect a lot of blue!!
chuck
Ingram, Texas
My headers are all ceramic coated inside and outside SS. The un coated 400 series SS turns a chocolate brown. The 300 series turns shades of blue. The mild steel headers rust over night, The ceramic coated mild steel rusts in a few mos.
ogr
Vail
Bear in mind I live in So. Az but I have untreated metal headers that were really rusty. I spent considerable time cleaning them up and then spraying with Rustoleum 2000 high heat paint and following there curing instructions. That was 6 years ago and they look like the day I sprayed them. If I had had the money at the time i would have opted to go with ceramic coated headers for the underhood heat reduction benefit. Chuck says they rust anyway so maybe my Rustoleum would provide the best of both worlds...reduced temps under the hood and uniform coloring of headers. I realize you are looking at ss for a consistent underhood look. Given the climate in your area that may be hard to achieve. Unless you have a climate controlled garage.
