Maxximus66
- Mar 25, 2020
- 9
So a couple days ago the starter on my ‘66 (170ci straight six)just started sounding like it was spinning and not engaging the flywheel... it was old so I just went ahead and replaced it . However , the new starter is not cranking the motor either .... it is somewhat engaging the flywheel as the fan is spinning , but , it doesn’t sound quite right and the fan seems to not be turning as hard as normal . I’ve got good charge and plenty of volts coming off a newly installed Optima red top . I’m banging my head here guys ..... could this be a shim issue ? A wrong tooth count issue for the starter ? Or just a bad reman starter ? HELP ! Thanks y’all !
