When I went to start her up the starter would make a loud spinning sound like a drill and would not turn over the motor. I replaced the solenoid up top and it started right up and just to test it I turned it off and tested start up a few times there was still a spinning sound occasionally but able to start. Now the new problem is it would not turn off even when turning the key to off and taking it out I finally got it to turn off...where should I go from here with the non turn off issue and still hearing the spinning sound with ignition? I'm thinking ignition swith and possible the starter itself due to the spinning sound but not sure. Any help is greatly appreciated..
