Starter manual vs auto
hankjr
Is it not the location of the teeth? Flex plate versus flywheel and the relationship of the teeth to the mounting surface. I think this is what I read at one point.
Hank
The pinion support/offset.
note for the odd things Ford has done; There is an exception to Ford starters in the auto/manual choices. Mustangs with the T5 transmission that you would think would use a manual transmission starter, actually use an auto starter. Just one of those oddities that can trip you up if you don't know about it.
Pa PITT
Stephenville TEXAS
Viperwolf1 Good post as usually . I learned something with your post .. But at my parts store back in the day .. We just said the nose is longer on one over the other.
