Starter Motor for ZF swap
Steve66
Monument
Hello -
I'm trying to figure out which starter motor to use after this swap below. Any help is appreciated. I searched around for this, hopefully I'm not duplicating a FAQ etc...
My 66 Bronco I swapped the motor and transmission from 200/3spd to:
- 302 from 1991 Crown Vic EFI
- The flywheel is 50oz imbalance
- ZF-5 from F150
- Original D20 transfer case
I'm just not sure which starter I should use, if it's specific for the F150 manual transmission? And if that's right maybe I'll need to make wiring changes to work with the 302 EFI..
Thanks a lot -
Steve
hankjr
Howdy. when i did my ZF swap, i got a starter from the same year as the trans. linking to EFI or stock wiring in my mind is the same (could be wrong) as its just a trigger wire from the ignition switch. the key is to makes sure that starter and flywheel are both from manual trans.
hank
S
Steve66
Monument
Thank you Hank -
I appreciate it. Don't want to chew up the flywheel with the wrong starter...
I was reading about the throwout gear getting stuck in other swaps and mostly worried about wrecking the flywheel with a bad fit..
