Starter motor feed wire routing
jckkys
Just got my '77 back from a professional frame off and discovered the starter motor feed wire was bolted to the exhaust manifold where it ignited on the way home. It likely would have shorted out on the next restart. Where was it originally routed?
JSBX
I ran mine on top of the frame using cushing clamps. I installed the clamps from the top using a 1/4" cordless impact with a long extension and self tapping screws.
ransil
I always put mine is a piece of radiator hose, that way I figured i would smell it melting if it got on the manifold.
I have had a starter wire burn thru before, melted my battery terminal and seen a guy with one in the middle of a hill climb rolling backwards pretty fast due to burn thru and shorting.
toddz69
It's been so long since I've had my stock one in there so I don't recall with 100% certainty, but I think it ran on top of the frame rail with a clamp or two holding it in place.
Todd Z.
Rustytruck
Its ok i thought it rand down from the starter solenoid down the fender well through a plastic tie down at the lower lip and just hung over to the starter. the cable was inside a brown fabric braided sleeve. With the new PMGR starter since its live all the time mine is inside a piece of heater hose tied down to the fender well with audel clamps.
J
jckkys
As you may have guessed, I'm not happy. I have the original insulated clips that didn't burn. The woven cover is what burned so it's past tense. I don't know if there is a way to replace it. The clips are the same distance apart as two 1/4" holes in the frame, my 1st guess for the original points to secure the cable. I would still love to see a photo of the OE cable as installed. Virtually all the fuel lines, brake lines, vent lines, and tubing need to be returned original configuration. My goal is an accurate '77 restoration with only '68 emissions equipment while being fully legal anywhere.
Top of the frame usually myself. I'm not really sure I remember the original location even if I saw it!
I've taken a few pics of original Broncos over the years though. I'll see if I can find one buried in there somewhere. Hopefully someone will find one faster than I will though!
J
jckkys
Thanks Paul. I'll try to make an '87 Crown Vic cable with the EB hold down clips and a cloth choke heat riser tube insulator that looks close to the OE cable insulator. It's a little long but that helps me keep it away from the exhaust manifold and pipe.
Rustytruck
check summit for insulated sleeves. I bought an insulated sleeve from them for my carb fuel line.
J
jckkys
I've found a lot woven tubes for heat insulation, but none look like the OE cable insulator. The '60s heat riser insulator does look right. I don't know what they were made of but it's not fire proof. No problem. It won't be near the exhaust manifold.
I've posted this one before. Unfortunately I was more interested in the original ground location and did not follow the starter cable down along the wheel well and exhaust manifold.
I don't have any memory of heat resistant sleeving on them, or clamps for that matter. Just the cable itself running down along the fender and under the exhaust to the starter. Very vague.
I'll keep looking just for your record. Sounds like you've got it covered with the "too long" cable anyway. I've always added length to the stock ones so I could route them farther away from the exhaust anyway.
I forgot to ask. Does that look like the end on your original? Or could this have been a replacement?
I've seen aftermarket cables with that type of lug on the end, but don't remember exactly what the early cables looked like. Mine was original when I changed them all out the first time back in the late seventies, but I think I only saved the ground cable and tossed the others.
J
jckkys
My engine to body ground cable was bolted to the back of the pass. side head and the fire wall. The terminals were ring type. The starter motor cable in the photo seems to be routed down towards the frame. The cable in my '77 also went down towards the frame from the starter solenoid. I never traced it further from that end. The starter motor end went up from the starter motor, most likely to the top of the frame. I didn't trace that either. My '77 wheel well is the original and has no holes along the bottom. So the frame itself is the best candidate. Paul's air cleaner looks like a 1970. Is that right? The ground cable in the photo looks like the battery to engine block ground cable with the battery end cut off. The loop seems to also serve as the engine block to body ground, because the loop isn't insulated. Mine was only secured at the battery and the block.
Interesting. And yes, that's how Ford grounded at least the early bodies. The engine ground cable was bare in that middle with the tinned conductors and that clampy doodle thingy probably soldered in place and fastened to the inner wheel well panel with a fairly healthy (#12 maybe?) sheet-metal screw.
The holes all looked pre-stamped when I've seen them and have all been in that same general area.
I've often wondered about the body ground to the firewall on '77's because I know one or two at least (and one of them was probably yours) that had them, while all the others I've seen including a few original owner '77's did not have any body ground from the engine other than the original style bolted to the fender.
It's actually a relatively late '72 (May of '72) but they kept that same snorkel (if that's what you were going by?) until the end of that year. The '73's got the cold-air intake setup. By late '72 the hole in the core support for the intake and the bump-out for the power steering box had already been showing up for several months.
Same Bronco I posted up a couple of years ago wondering about this unknown relay array on the driver's wheel well.:
By the way, in what month was yours built? Maybe if it was a later build that might explain why yours got the body ground from the engine (like almost every other car built at the time!) while others did not.
Rustytruck
my 1974 Bronco had a firewall ground behind the passengers side head. the wire went from the bolt that held the tranny dip tube to the firewall right behind it. sheet metal bolt with a star washer on the firewall and a star washer under the dip stick tube bolt. I remember removing it when I had to pull the tranny it ripped the hell out of my hand to get the dip tube free. needless to say I did not put it back on. I ran a different body ground after that.
J
jckkys
Paul, yes all I could see that implied a year of manufacture was the forward pointing snorkel that was used from '70 till the cold air system was used in '73 I think. My '77 was a late in that year built. I bought it in Aug. I think. It was a demonstrator the dealership owner used to get to work. I saw the new '78s were not the EBs I loved and I was ready to take what ever I could find in late '77. I had owned a '74 that was a late '73 build. Got T-boned in that one. I've changed a lot of things in the '77, like 3 on a tree to C4 and a 351 that looks a lot like the OE 302. I am trying to build the '77 the way Ford should have, with what was available in '77 and the years I was paying it off.
Did the ground strap get replaced during the restore, or is it still there? Would like to see what style it was. And yours as well Rustytruck.
Were they braided straps, or covered braided straps, or thick covered standard wire (approx. 10ga maybe?) or something else?
