Starting problems
EASYRIDER
goodlettsville
Hey guys i have resently bought a 1974 bronco sport i have had to put factory wiring harness back in the truck,and have ran into an issue when i try to start it the silinoid will click once and then i loose power to everything. i can disconect the battery and hook it back up and i will have power back to lights wipers ext,but have to wait a few minutes.Not sure where i should look first any help would be great.
Viperwolf1
electron whisperer
Your not supposed to start problems, you're supposed to finish them.
Sounds like either a discharged battery or poor cables/connections.
E
EASYRIDER
goodlettsville
ground is also good any other suggestions.The voltage regulater hums when using test light to check voltage to wires, is this normal or would it suggest its bad.
Viperwolf1
electron whisperer
The one click means it's getting at least a couple amps to the solenoid coil. No click after that means it isn't. How do you know the battery is good? Voltage can be relatively high (~12V) and still not deliver enough current to turn on the solenoid or lights. You need to load test it or put a charger on it.
Cables and connections can look good externally and still be bad. You need bare metal contact at all the connections. Cables can corrode on the inside. If the cables are stiff or the insulation is swollen they are bad.
A shorted starter can pull excess current without turning. It can pull so much current that the battery needs time to recover afterward. Might have the starter tested.
A locked up motor will act just like a shorted starter. Might see if you can turn it by hand.
Regulator has nothing to do with starting circuit.
E
EASYRIDER
goodlettsville
Thanks ill look everything over, motor is free ive already check that ill test battery,and starter is new but if the other stuff doesnt work ill have it checked thanks for the help
