Steering box rebuild necessary?
bflippinw
Cleaned up the housing, luckily po just painted over grease so it power washed clean easily. The input shaft turns easily by hand and no sign of drag. Should I send this to be rebuilt just because or is there any more checks to be done?
I got the box in a pile of parts so not sure if there’s gonna be leaks.
rjlougee
My $.02:
If you have a plan to use it, can afford the rebuild and don't need the box right now, I'd rebuild/have rebuilt.
The big question: should you have it ported for ram assist steering while it's there???
HTH, Joe
B
bflippinw
Any other advice, should I just try a re seal kit.? Box seems to turn smooth, no slip.
unimogger
Philthadelphia
I just resealed mine, probably a 2 hour job after the box was on the bench. Theres a video on youtube that details the disassembly pretty well. You have to remove the top cover and main shaft to get access to the two seals above the pitman arm. Getting those out was a chore, as theres a bearing behind them that you don't want to damage. But all in all, not too difficult. You don't have to go in so far that you have little parts falling out.
Qumanchew
Kutztown PA
A lot of times slop doesn't show up till it's under load, in use. Hard to say if it needs to be rebuilt till you use it unfortunately.
