Steering box removal
Jeff76
Alpharetta GA
Hi guys,
Been a long time! I've got a bit of time to tinker with my 76 and remove the stock power steering box for some repairs. Question is when I remove the lower steering shaft, do I need to mark the position relative to the box flange or is it keyed? Pump has been leaking so it's very grimy. I have it loose and ready to pop out just wanted to check. Service manual verbiage and diagram is sufficiently vague on this issue.
Thanks!
Jeff
thegreatjustino
Red Head Grease Monkey
Stockton, CA
While you can install the ujoint onto the box in any orientation, you will only be able to get the bolt in if the hole in the ujoint is aligned with the slot in the input shaft of the steering box. So, align the two first and you should be good for reassembly.
Slowleak
Georgia
I just did that on my 77. The bolt holding the lower shaft to the box fits into a notch cut into the shaft coming out of the box so it will only fit back the same way.
Jeff76
Jeff76
Alpharetta GA
Thanks guys! Looks pretty simple in hindsight. I think it's keyed as well about 90 degrees off the indentation for the bolt.
Jeff
