Steering Column Shift Tube
edge4
Gonzales, Texas
Iv'e searched all the links and forums and cannot find the answer. Is it possible to remove the shift tube if your not using the tree shift anymore? Does the steering shaft need this tube for any support?
Also my 74' steering wheel has two spring wipers, where my 76' does not. I know one is for the horn, the other I found the wires cut. What was the other for?
BlackHorse
You can take out the tube. It has nothing to do with the steering shaft. If you take out the tube the shifting collar will not have anything to attach to so you will want to remove that as well. Then you can get a collar from a Falcon or some other old Ford and put that in its place. The column will look like stock with no shifter. As for the horn wipers I believe the old style two wire type is power flow to the horn. If you jump the two wires you will here the horn. Power in, power out. If this is wrong someone will let us know.
JTCamp
Austin, Texas
Yes the earlier style horns didn't have a relay and used 2 horn contacts to directly connect the power. The later models used a relay with one wire.
