pcf_mark
- Joined
- Jun 11, 2010
- Messages
- 3,647
First question for anyone who uses aftermarket solid u-joints in their steering column. I have replaced my lower shaft ages ago with Flaming River stainless steel joints and shaft. Works great, looks great.
Do you find they transmit a whole lot of vibration through the steering wheel? When I had the stock tires it was ok but now that I have much larger tires the wheel is alive with a slight but noticeable tremor at all times.
Second question - how do you adjust the steering linkage to center the wheel? On a traditional tie rod front end you can move each end a little at a time and center the wheel while keeping the toe setting. On our trucks this is not an option because if you twist the drag link you can adjust tow in and out but not relative to the steering linkage. The link between the steering box and drag link would need an adjustable feature. Do I take my wheel off or pull the column out and move it over a spline or two where it goes into the u-joint? Or an I just missing something here?
