Steering Wheels for EB's
eBronc
Austin, Texas
Junkyards are so cool.<br><br>I spent a few hours snooping around one of my favorites, and found a great 15" dia, black leather wrapped factory Ford 2-spoke wheel in a mid-80's F150...$6.00. Fits my '70 Bronco column great (after just a little work with a round file.) <br><br>For the record, my '70 Bronco column is 11/16" dia, 40 splines. <br><br>Also found a T18 granny gear 4-speed, two 8 lug full-floater rear D60's, two 351W's, and quite a few EFI 5.0's and other Windsors w/serpentine setups, just ripe for swapping. <br><br>I even stumbled across (literally) a complete 3.0 DOHC SHO V6 - I've been searching all over the 'net for one to swap into my '66 Porsche project. The guy wants $500 for it, though...a little more than I had in mind.<br> <br>One side effect of seeing all those wrecked, rolled, crushed, and burned vehicles in one place is that you drive real careful on the way home...
eBronc
Austin, Texas
Here's what I found in the junkyard, after a little cleaning - not bad for $6.00<br><br>
<br><br>
admin
Administrator
Just your friendly, neighborhood webmaster...
Phoenix, AZ
Hey Jon, what size lecarra wheel did you get? I too have been looking at replacing the cheapy grant i picked up for like 20 bucks with something nice like a Lecarra. Thanks...
Sorry for taking so long to reply. It's a 14" wheel. I got the Mark 9 Bordeaux (Bordeaux is the two-tone version) It's a nice wheel and the aluminum adapter is really nice too (kinda pricey) Here are some pics. Click each for the larger version:
brian72
Early Bronco Student
Can any steering wheel be used with the grant removable kit or just grant??<br><br>I really like the removable option. <br>thanks<br>
boatbldr
Fort Collins, CO
I bought a grant with adaptor and installed it. I discovered the adaptor just wasn't a good fit, causing the wheel to seat too far dwon on the <br>shaft. I't mashed the c**p out of my horn button, almost ruining my brand new $70 turn signal switch. I promptly removed and returned<br>the pos. I might take a chance on the Lacarra, but watch the installation with the grant.
kxbronco
Knoxville, TN
I picked up a Grant 870 Challenger Series (3 spoke) at a yard sale for $3. Put it on last week and it was to close to the blinker arm. I got the Grant 2" extension kit and this makes it a little closer to the driver than I would really like. All in all, the wheel was fairly easy to put on, but that horn is still being a pain to get working.
KST1
I have a Grant wheel Part #? with the adapter kit. Like boatbldr my adapter seated kinda far down. Ever since I put it on I've had a squeek. Turns out it was the horn contact ring smashing the rubber mount for the horn contact. I took my Dremel to the rubber and made a little clearance. No squeeky squeeky! <br><br>I also replaced the upper column bearing and bushing while I was in there. Sure makes the wheel feel smooth!<br><br>-D
