Kyle.malone
So... Two weeks ago, I got the bronco started for the first time in two years.. Had a heating issue. This past weekend, I went ahead and changed the water pump and the thermostat (180 degrees) It was a quick and easy change. With a little bit of success, but its still running hot (210). When we got on it to see if it would hold temp, more white/light gray smoke filled the barn (It is a fresh rebuilt 302 with a .030 bore, new cam, rebuilt heads, and new intake) and the temp went up. I now have the idea to buy a cheap mechanical gauge and see if my new electrical gauge is working correctly. (my electric fan does not come on at 180 like it is suppose to and I had to hardwire it to the battery for testing. I know that it has power on the keyed on position becasue my fuel pump relay is on the same power line. Does anyone have any other ideas that it could be?
I do recall someone mentioning a fan shroud, but since I am running an electric fan, I didn't think I should need one. The fan I am using is rated at 1610 cfm. It's setup as a puller and we can feel the air being moved.
