Engine still running after key off
Tulsa76bronco
Hey EB just started this when I turn key off engine still runs a little sputters then may or may not do a small back fire
What causes this it is just recent
broncnaz
A few different things can cause it. To much timing. Idle speed to high, carbon in the combustion chambers, to rich of a fuel mixture ie like a stuck choke. Probably a few other things that can cause it as well.
Tulsa76bronco
Tulsa76bronco
Idle at 700, I have a Holley TA 600 only a year old how do I see if choke stuck? How do I check or fix the carbon on chamber
broncnaz
It could be a timing issue. need to recheck your timing. To check the choke When fully warmed up look at the choke plate see if its fully open ie straight up and down more or less. Also look for fuel dripping down the throat of the carb that can mean the float setting has changed or the needle seats are leaking.
There are a few ways to try and clean out carbon from the cylinders. one is use some aftermarket cleaners like sea foam just pour it in the tank and drive it. Other methods that seem to work well are to fill a spray bottle with water and while the engine is running and slightly reved up start spraying the water into the carb. This will make steam in the cylinders which should clean them up. Just keep the engine running while doing this. Another similar way is to use ATF.
broncnaz
You may want to pull your spark plugs and have a look at them that can tell you a lot about the engines state of tune. could be also be running to lean and the plugs are getting hot igniting the fuel mixture without a spark.
Steve83
Deposits in the combustion chamber raise compression, but so do other factors.
Since the cleaning process doesn't hurt anything (if done right), it's OK to clean it anyway.
With the engine FULLY warmed-up to operating temp, and at high rev (~1500-2500RPM), drip or spray clean (distilled is best) water into the throttle. That's pretty much it. You want to get JUST enough water going in to make the engine cough, but NOT anywhere close to enough to hydraulic a piston. That's why the RPM has to be far above idle - so there's enough airflow to keep a puddle from forming anywhere, and then suddenly splashing into a chamber.
Just like when a head gasket leaks & allows coolant into a cylinder, the water starts to evaporate when it hits the hot metal. But when the piston compresses it, it liquefies again and is forced into the pores of any carbon deposits. When the cylinder fires, the water explodes into steam, blasting the carbon off. If there WAS any in your engine, you should see the exhaust turn dark initially, and then get whiter as you run out of carbon in the engine.
Keep it running long enough after stopping the water to be sure that no liquid water remains in the intake, and very little in the exhaust (there will ALWAYS be some there, even from normal driving).
Hozr
Rogue Valley, OR
Basically something in your combustion chamber is creating a "hot spot" which is continuing to ignite fuel without spark. This can become serious because if it occurs at the wrong time it CAN (while not likely) reverse the engine rotation. If it does you will see/smell exhaust come out the air cleaner - FUN!
What has worked for me in the past:
Verify timing is correct (not too high)
ReAdjust Idle screws
ReSet idle RPM
Check High Idle / choke linkages - they can stick on the TA's
SEA FOAM!
you can also try:
Colder spark plugs (-1)
Higher octane fuel
I'm not a fan of water in the intake.
Tulsa76bronco
Tulsa76bronco
Choke plate looks straight up when warm
Choke plate when warm
Tulsa76bronco
Tulsa76bronco
Also did the carbon cleaning with the distilled water. I didn't notice anything different out the exhaust. I was only able to check one plug and it didn't look black so all that seems ok
broncnaz
Choke looks good. Did you check the plug before or after carbon cleaning? If before was it clean or any color at all?
Tulsa76bronco
Tulsa76bronco
Checked
Checked it before white part is good the end could be a little dark but I thought it wasn't too bad
broncnaz
Uhm you pulled the spark plug out of the head right? Have you checked the igintion timing yet? how much are you running?
broncnaz
Lol pics never lie. Anyhow timing is probably most of your issue. Some parts stores will rent you a timing light if you cant find anyone that has one. Another thing you could do is loosen the distributor bolt and turn the dizzy counter clockwise slightly see if it helps any. But its best to have a timing light so you can check your actual setting.
