...right now i just have a 3 speed with about 88,000 original miles from what the older gentleman owner told me but it runs strong so could be true, anyways is the original 3 speed just junk?
No, not at all. In fact it's one of the nicest transmissions ever made.
It's smooth shifting, quiet, very reliable when not abused or used in too heavy of a working vehicle, inexpensive and simple to work on.
It's main weakness as far as I'm concerned, and as far as 3-speed trannies go, was the piss-poor choice of gear ratios for a truck. Even the close-ratio version, which had a great 1-2 shift range, sucked for a Bronco (would have been sweet in a lightweight car) big time because then the first gear, which was already too high, was just WAYYYY too high for a heavy rig and off-roading.
Yes, even in low range!
I mean it is factory tranny,do people just want more out of a tranny,is that why they switch?
Exactly. It's a 3-speed, and has lousy gear ratios for many users. Not everyone of course, and there are still a lot of Broncos running around with their original gearboxes in them. Driver's still smiling too.
But many of us that went off-roading in our Broncos wanted at the very least, an under-drive first gear. AKA granny low.
And those that spend much time on the street with the optional 4.11's and 4.56 gearing in the diffs were always hunting for another gear on top of third. Funny how often you actually try to shift into one too, after converting from a column shift to a floor-shift setup. Drive even one 5-speed with overdrive in your life and you end up always wanting that extra gear in whatever else you drive.
It's all about convenience and efficiency and just having more choices.
Also if you were to replace it and mostly on road but want it capable off road would you go with an ax15 or nv3550?
Either one, but that little bit of extra low gearing in first gear of the 3550 does give it a slight advantage off road. Depending on what type of off-roading you do that is. The AX probably has a better overall gear spread for shifting and keeping the rpm in a good range each time, but that few extra points that the 3550 has in first might just give you an advantage.
I drove mine a lot. And for all those years of lusting after an NP435, NV4500, or anything with even remotely better gear ratios, there were many circumstances where there was just never the right gear with just 3 to choose from. First was too low for good street manners, but too high for off-roading. Second was never where you wanted it and the jump between it and third was a deep one and if you were loaded up for a weekend's worth of camping and did not have the engine revved to the moon, it would just bog down in third, then over-rev again when you had to shift back into second.
More and closer spaced gears is almost always better. Not always 100% necessary, but still "better" for most conditions.
Which is why you now not only have 5-speed manual transmissions and 4-speed autos, but why 6, 7, 8 and even 10 speed transmissions are the norm in almost every lineup of vehicles. The new Bronco even has what? A 7-speed manual transmission?
Hmm, I wonder how one of those would swap in!
I heard jim at wild horses say on a video they are basically the same tranny,are there any differences?
Sure, but I could not quote you each and every one. Basically the reason they're considered the "same" as each other is that they are almost identical in physical size, have the same number of gears, with almost the same ratios, and probably have similar reliability records.
I can't tell you one is better than the other because I have not spent any substantial amount of time with either one.
