cody72sport
- Joined
- Mar 31, 2009
- Messages
- 796
just wondering what your experience has been with a stock 4 turn power steering box and 35 inch tires, thanks guys!
zero issues. Are you just concerned or is there an issue?
If you ae not getting enough assist its likely a pump issue and not the box when using larger tires.
I added a hydraulic ram for assistance. If you rarely go off-roading then skip it. On road is a non issue, but locked in four wheel drive is another story. I also have a front locker and steering was non existent. Best upgrade for the trails and off-road.
I'm with big muddy. Box should be fine but if you still have a ford pump I'm may whine and struggle. Look into a Saginaw pump.
I'll be doing gears and lockers in the near ish future and want to plan ahead whether I go 4.56 or 4.88 depending on tires
I was thinking true track or track lock for my front axle. how does a ram behave on the street? I'm going for a well balanced street to intermediate off road build
Good to plan ahead. But do you need a real locker? You later mentioned some limited-slip diffs by name, and those are easier on the steering. But are you planning many off-road excursions? And if so, how hard? You mentioned intermediate, but where and what type of wheeling conditions? In other words, the "everybody does them" Colorado mountain pass trails? Some muddy off-road parks near you? Sand dunes? Sometimes intermediate can put a lot of stress on stuff.
Hence my question as to whether or not you even need lockers or limited-slips (two different categories by the way).
Of course, you were not asking about that aspect, so I don't mean to pry...;D But it is pretty important info when it comes to recommending a critical item like a steering box.
I do know plenty of people who have wheeled with 35's and stock boxes. And some have gotten MANY years of good use out of them too.
But most of them eventually broke! So saying it's good enough might be true now, but what about ten years from now when you're far from home with a cracked gearbox puking it's life out on the ground?
I'm with the others in general. For the street the stock box lives just fine even with 35" tires. But take it off road much, and add some type of traction differential to the front, or use your equipment fairly hard, and all bets are off and it's time to consider a beefier box.
Agree with Steve too, that if you end up with 35's you'll be happier with hydroboost brakes. There can be good vacuum assist brakes, but they're few and far between and not something I'd stake my life on.
what kind of locker are you running? I was thinking true track or track lock for my front axle. how does a ram behave on the street? I'm going for a well balanced street to intermediate off road build
I'm in southern new mexico, so there will be a lot of sand and a little bit of crawling. the old chile challenge trails are nearby and id go on the easier ones (they go all the way into extreme waterfall climbs which i have no interest in)
I'd also like to make some trips to moab and run the moderate trails
i was leaning towards a true track out back and a track lock in the front since the front axle isnt going to accumulate enough miles to wear the clutches very quickly. I'm nervous about a detroit locker in the back because im going to be running around in the mountains where my folks have a cabin on very steep paved roads that will often be wet.
Cody, My father's old Bronco was running a Detroit in the rear on 35s with 4 turn steering and manual brakes. The steering was fine, but the brakes could have definitely used power assist. Hydroboost is better, but a vacuum system will work fine. Ram assist can work just fine on the street if you have a properly done system, but I don't think the hassle will be worth if for your use.
For Las Cruces, I wouldn't hesitate to run a Detroit in the rear (The Grizzly from Yukon is a better option), but if you anticipate driving on ice much wherever the cabin is, you will want to go another route. My experience on the rocks is that limited slips are hardly worth bothering with, and if you are worried about the drivability with an automatic locker, I would suggest saving up for a selectable locker. Personally, I would rather have a selectable locker in the rear than two limited slips. My father's Bronco did all the hard (non-extreme) trails in Las Cruces and most of the famous Moab trails with just a rear locker; although a front locker would have been really helpful at times.
I would highly recommend a selectable locker in the front even without icy road considerations, but if you are willing to live with the front end pushing off road, an automatic front locker is certainly livable.
If you are dead set on limited slips, the True Trac is about the only one I've seen that works worth a darn on the rocks. DO NOT waste money on a clutch-type limited slip. They are absolute garbage.
Just for reference, I have owned 4x4 rigs with open diffs front and rear, limited slip rear open front, automatic locker rear open front, automatic lockers front and rear, automatic locker rear selectable locker front, selectable lockers front and rear, and welded front and rear on tires ranging from 31"-38", with manual brakes, vacuum boost brakes, hydroboost brakes, manual steering, and power steering (none with hydraulic assist) ;D
EDIT: Also, this would be an excellent time to upgrade the rear axles to 31 spline. My father never broke a stock 28 spline shaft, but he was a very conservative driver. In order to upgrade later if you find yourself breaking axles, you'll have to buy a new carrier again
Im on the fence about hydro boost, because i have a vacuum booster and bracket sitting on the shelf that i bought used for a good price, and i like the idea that if i shredded my power steering belt id still have power brakes to drive home
the cabin is up past cloudcroft almost to bluff springs i dont know if you're familiar with that area, the roads border a lot of deep ditches and canyons so sliding off the road would end really badly
which selectable lockers have you run and how has reliability been? Id thought about selectable but the cost would delay it a while and im about to swap an ax15 in and id like to be able to use the overdrive sooner rather than later
Im definitely going 31 spline and probably swapping out the small bearing housing for a large bearing at the time i do gears
