Always loved the 4100s. I'll bet that and the stock 4 barrel intake produces better torque than the high rise and Demon. Today I tried the '68 lever thing on a '77 and found out that on the early bell crank, the inboard leg is bent back about 30 degrees and the legs on the '77 are almost parallel, so they are made to work together. I'm not swapping the bell cranks. There's too many hurdles too find way to use the lever linkage, so I'm going some other way. I think the best thing is an extension on the carb's throttle lever that places the ball stud above and slightly behind the throttle shaft. Also it will be as far from the throttle shaft as possible while allowing full depression of the accelerator to fully open the throttle.
