Stock body mounts
extramedium9
Long Island, NY
Are the stock body mounts all the same height? Or are they varying height for different body mount locations.
I bought the 1" Wild Horses lift which are all the same height and things are not sitting right.
Chief Master Sergeant
Retired U.S. Air Force
Somethings wrong somewhere then, because I just replaced mine with the WH 1" body lift and it sits perfect. They should all be the same height. Of course with age, I'm sure the old mounts could have smashed flatter in a few spots.
If you had those thin steel washers under any of the originals, did you replace them in the same spots? Most times the factory has some of those shims between the cushions and the body
E
extramedium9
Long Island, NY
Dirtdonk,
That's interesting, I didn't know they had metal shims. I don't recall there being more than one washer on top of each of the body mounts. The gaps I have appear to be a lot more than shims would make up anyway.
The problem I have is that after mocking up the body panels ( 1" WH body lift, fiberglass tub, all aftermarket metal front clip, fiberglass fenders, and stock grill, on a frame which I bought from a member because the original had a lot of rot) the body lines are very off.
After putting the tub on the frame with the body lift, there is a 1-1 1/4" gap between the body and the body mounts by the driver/passengers feet. If I mount the rest of the panels to keep the body line straight, the gap at the core support mounts is probably ~2". I tried just pulling down the body with the bolts to get rid of the 1" gap, but this screws up the body line by pulling it down there.
Could my frame be that bent, sloping down starting around the front tub mounts??? Can I measure the frame somehow? Any other suggestions? This has put a serious hault in my progress.
What a pain. Yeah, a 1/4 to a 1/2 inch here or there is not uncommon, but the gaps you're dealing with are pretty severe. The factory shims are pretty thin, but typically stacked several deep to get the desired size. Maybe up to about 1/2" or so from what I've seen. Maybe more if it's really needed.
For some reason, I seem to remember seeing most of them on the passenger side front mounts most of the time. Both my Bronco and my '79 pickup had them under the right core support, and the right front cab mount (under your feet) but I don't know if that's always, or just the few times I've found them.
It's very possible that after all these years your frame is tweaked. I don't know how to check it, but I remember someone posting (a long time ago now) a spec sheet with all the body and frame measurements. Maybe a deep search will turn up something. Or hopefully someone will have that info handy.
It's also conceivable that your body is slightly off too. I imagine they take pretty good care to get them straight, but if it's a bit off, and your frame is a bit off in the other direction, you'd get this kind of problem. Is it possible that your front steel and main fiberglass are not quite matched up? Can you set up some little stands on flat ground to verify that the body's mounts are flat? Can you measure up from the ground to the tops of the frame mount pads to verify that they're all the same distance from the ground?
I don't know if that's accurate, but it seems like it would help get you close.
If you can't measure them to verify factory specs, you might just have to build spacers yourself to compensate for the gaps. Getting the body panels straight seems to be the prime goal here I would think, so a spacer to accomplish that would be important.
Good luck.
67u13
austin texas
The bushings have a "ledge" that is supposed to center them in the hole, perhaps 1 or 5 are not properly seated? Maybe old bushing material still there?
