Stock Gas Tank Conversion!!!!
broncoitis
I think that I am gonna give this a try and wondering if anyone might have some advice they can pass on to me or even if this is even possible.
Worst case scenario I ruin a small polyetheline tank and have to pony up the big bucks for an aftermarket tank. LOL!
Here is the plan. Currently in the process of converting my truck to EFI but only have an aftermarket polyetheline tank to work with. I have a fuel accumulator that I bought for this sole purpose but don't really wanna figure out where to mount that monster in the engine compartment or have to deal with mounting and wiring up high and low flow pumps.
Because the tank is made from polyetheline, I can plastic weld it back shut after the modifications. Gonna install a bracket to mount the pump to and fabricate a baffle to keep the pickup submerged in fuel in those off camber situations. :cool: Also gonna route the fuel return line to dump the fuel directly back into the baffle to keep the pickup submerged in fuel.
Anybody have any thoughts or ideas to add that I may be missing because I have never done anything like this before. Let me know!
Other big reason for the conversion is that I really can't justify spending the $400 to $600 dollars for a new tank. ;D
hmh800
Go for it! I did a similar mod on my old CJ7 that I put a 5.0 motor in. Although I just fabbed a pump mount to the fuel sender and used the stock fuel line where it passed through the sender mount. It worked great, no probs. I think getting the pump in the tank is key- avoids a lot of potential problems. Haven't gotten to it yet, but I plan to try the same thing on my 68. I'd like to mount the pump on the sender of the rear tank, and install a small transfer pump between the main tank and the aux tank. That way I can use both tanks, but don't need to deal with all the extra plumbing and potential issues. Good luck and let us know how it turns out!
broncoitis
broncoitis
HMH,
Thanks for the encouragement. I think that I am definitely gonna give it a go.
That is exactly what I am gonna do. Weld a mounting bracket to the factory sending unit and go from there.
Once I get this started I will definitely post up some pics of what I did and how it all worked out.
going with 19lb injectors with the EFI conversion. Will it be a waste to go with a slightly higher flow pump than stock or will that be a complete waste?
broncoitis
broncoitis
Viper,
Thanks for the reference info! Definitely keep all that in mind during the conversion.
This might be a Dumb question, but gonna ask if anyone knows anyway. The Sending units are galvanized steel and not Brass or something else? ?:?
broncoitis
broncoitis
Thanks, that is what I was thinking but you never know I guess.
Any thoughts on the pump guys? The fuel pressure regulator is what determines what pressure the injectors are getting. Right? ?:?
broncnaz
I'd say it would probably be a waste to go with a higher flowing pump especailly if the plan is to run 19 lb injectors. stock pumps can easily handle 24 lb injectors so really higher flow isnt needed with 19 lbers.
ransil
use one of these for a fuel pickup , no need for a baffle.
http://www.liquidironindustries.com/home.php?cat=273
Put the return line in the filler neck.
add a fuel pump to the pickup tube..
I used an accumulator on my first EFI install, I think its a waste of money and time to find a place to install it.
cheapest & easiest route
Just use an external HP pump mounted close to the tanks as possible and the return line in the filler tube
broncoitis
broncoitis
Ransil / Bronnaz,
Thanks for the additional input.
I was under the impression that the High Pressure pumps that worked best were mounted in the tank?
hmh800
I agree that ideally the pump should be in that tank. Not as easy to access but I've never had one leave me stranded. Stays cooler and out of the elements that way. Quieter too, I'd imagine.
ransil
Ransil / Bronnaz,
I have seen intank pump go bad as well as external,. just depends on how much work you want to put into it.
an external pump can be changed on the trail very easily, I once saw a guy cut a hole in his bed to access his intank pump then after removing it found he was just out of gas.
I have a fuel tank I'm working on that will have an intank pump. But I have no problems running external pumps on my rigs.
