In the process of putting things back together (retrofitting my '70 with power steering off of a '76. Have a few questions for those of you in the know:
1. Is it necessary to shim with washers the upper bolt on the PS pump (the one with the long bolt that screws into the block and comes through the bracket that bolts to the water pump), or should it just fit loosely. allowing the pump to slide back and forth a bit.
1a. when screwing this bolt into the block, do you screw until it bottoms out, or should there be some sort of nut to lock it in place?
2. What size bolt goes through the "bottom" hole where the PS cooler mounts?
3. Any other hints on putting on the power steering?
4. Where's a good place to reloate my ignition coil? It was on the front of the block on the driver's side, right where the cooler and PS pump need to mount up.
Apperciate all of the help - thank you guys!
Jerry
Jerry
