- Sep 21, 2020
- 43
Hey again ya'll! Here's the deal:
- Reviving and restoring our '68 Bronco. Hasn't run in over 2 decades.
- It has a really hacked-in power steering setup
- Motor is a Mexican/HiPo 302
- I have a donor steering box (and original reservoir if needed). Sent the donor box (which is from a '72 Bronco) off to West Texas Offroad to be rebuilt and resealed.
I'm wanting to know if you all have any advice on:
- is there a bracket, or bracket and pump kit, that will bolt onto the 302? I found this link, and even this one, but unsure if it's precisely what I need or not for bolt-on to this 302. Anyone happen to know?
- regarding mating the existing column's shaft to the new box (see photos, how is this normally done in going from early (non-power steering) to a late (power steering) Bronco? Whole column replacement? Or some kind of double D joint or two? I have the stub of the donor column where it was cut about 12" from the box (which you can partially see in the photos below)
Would love any advice or help - thank you in advance!
