Re:Stop heiming and start hauling
I don't have that setup on mine, but I have seen it on other Broncos, looks really clean and I've heard that it functions well. There was a posting a while back about this same subject. Basically what it boiled down to was that it isn't DOT approved because if it (the joint) fails, then you lose your steering (the joint can pop apart); whereas in the stock setup, or something DOT, you will not lose your steering, it will just get really sloppy. Either one is suitable, it wont really feel different on the street, it just helps in the flexing department. However, a lot of people were saying "if it isn't broken, why fix it?" Mostly because they hadn't heard of anyone having problems with the stock or F150 setup, flex-wise. I have the 78/79 Bronco tie rod on mine (with tie-rod over conversion), and the shafts are as thick as any that I have seen on any pickup truck, and they are solid metal. So, for 400 some-odd dollars, I'd say that it isn't worth it. You can find equal or better alternatives out there, for less money, and is still DOT. <br>-Eric
