Strange problem going into 4wd low.....
luderchris
SouthEast PA
Most times when I first put the truck in 4 low, when I start moving, I am only driving the front wheels -- it is front wheel drive. I believe everytime I put it in 4 high it goes in just fine and all is well. I go back to trying 4 low and the same thing happens, just front wheel drive.
Up to this point, I can eventually get it in 4 low (lots of shifting the TC back and forth and driving forward/reverse), but I am very confused as to why/how this is happening.
Any thoughts?
Thanks.
broncnaz
If you have a T shift type of shifter the pawl plate might be misadjusted and not letting it go into 4L.
1970mule
look at the linkage from the shiter to the tcase, for the jtype it has metal tabs connecting to the shift rails on the tcase, for the tshift it just has bolts directly to the shift rails. i beleive you have the jshift becase it has the ability to go into front only drive and rear only, biut i have only seen that with the twin stick. i would check to see if something is not loose or broken with the linkage.
zeeman1
Seattle
With a NP205 if the shift rails have been modified to allow front wheel drive and you don't have twin sticks this would be an issue. One stick works when the rails only move where they are supposed to, but once it's setup to do the 2low and FWD you should go twin stick to make sure you have it in the right gear.
Try taking the shifter off, put the right shift rail (rear) in neutral. Then try putting the left shift rail (front) into gear. If you can put it in 2wd then it's time to get twin sticks.
If you want to pull it apart here is how you can tell for sure...
http://www.members.cox.net/russhuffman/twinstick/twinstick.html
