Strange Starting/Electrical Problem - Viperwolf, ya there?
HoldMyPocket
Charlotte
The other day I had been driving my Bronco all day and that evening decided to run down to the store. So, I went to start it but I didn't give it a pump of the gas pedal and it failed to start.. but then I turned the key off and back on again before the starter had fully wound down from the previous start-attempt. This killed everything.
I turned the key again and I heard what sounded like the solenoid click briefly then quit. Tried my headlights and got nothing, no stereo etc. Checked the battery and it read 12-something volts. Hooked it up to a charger anyways , cleaned the terminals, checked all connections, and jiggled the cables. Went and tried the headlights and they worked again, so did the stereo. Tried to start it and all I got was "click." Tried the headlights/stereo, nothing again as if the battery was dead.
Today, I pulled the starter and had it tested and it works perfectly fine. Flywheel looks good, and the motor turns by hand. I'm going to put the starter back in tomorrow but I suspect that was not the issue.
So to me it sounds like there isn't enough power left after I attempt to start the truck and fail. I think I may replace all the battery cables, triple check my grounds again, but those sound like things that would pester me gradually rather than suddenly like this after driving the truck every day for the past year.
I have a Centech wiring harness and was thinking maybe I burnt up this wire:
Any input on that theory or any other suggestions?
TIA
Viperwolf1
electron whisperer
Definitely a bad connection. I would suspect either that fusible link with the crimped lug or pos/neg battery cables. Those would cause the lights and stereo to die. A bad starter cable wouldn't.
redtail
make sure your battery cable - is connected properly, I had this happen to me and it took a while to figure out. The bolt on the block came loose.
69red
Cochrane, AB,CAN
This happens to old red once in a while. for me, its always the bunch of wires on the bat side of the starter solenoid. I just take off the nut, polish all of the wire-ends and the nut with #200 sand paper and re-attach tightly. its on my list of things to fix, but ... well you drive a Bronco so you know.;)
Good luck
HoldMyPocket
HoldMyPocket
Charlotte
So.. I checked the fuse link+battery cable with the multi-meter and it seemed fine. Took out the crappy non-stock ignition switch that came with the Centech wiring harness and checked continuity and found it to be intermittent in on/start.
So.. I couldn't find a replacement ignition switch at Autozone and ended up ordering a whole new ignition switch/barrel/bezel/door locks etc from Tom's. I'll keep yall updated.
Justafordguy
Doesn't sound like a ign switch problem to me. If so the lights would still work.
The multi-meter really doesn't test the battery cables because you will still see voltage when there is no load. You just need to disconnect all battery cables and clean both ends then bolt them back good and tight.
patterdale
How old are the cables? They can appear good but be messed up inside as far as 6". If there is whitish powder it is a sign that they are corroded up inside the insulation.
Squid
San Diego
I had this same thing happening a week or so ago. Sometimes it would start with slow turn over, and other times just click click. After reading a lot of posts on here I determined it to b a ground issue. I went and bought a new negative terminal from battery to block along with another cable to go from that same block connection to the frame. Finally, braided cable from a bolt on the intake to a bolt for the power booster on the firewall. Problem solved.
Squid
Broncmeister
I'll add my voice to the bad cable groupies. Either a ground cable or the power from the battery to the solenoid.
HoldMyPocket
HoldMyPocket
Charlotte
positive battery cable corroded like hell! Oh well.. in the end I wound up with a new stock ignition (the stock Centech one I had was actually in bad shape but that wasn't the core problem obviously), a new starter cable, positive cable, and ground cable.
HoldMyPocket
HoldMyPocket
Charlotte
Hmmmmm? Didn't somebody tell you to change those a long time ago?:cool:
yeah, yeah. Funny thing is though, this was the brand new battery cable I bought when I put the motor in. They're just crappy. Will have to invest on nicer cables. Now that I have my own garage to work on it in I can actually stop procrastinating and get things done right!
