stretch
Huckit36
Hey guys, I am wanting to stretch the rear end a few inches and looking for ideas and recommendations from anyone who has done it already. First, what wheelbase is ideal to shoot for? 101"? I know ill have to cut the wheel wells and im assuming ill have to move the gas filler cap, but can i leave the tank in the stock location? Im already running a WH sherman tank.
I am already on 37's and have a pretty good amount of travel but am thinking 4 link it.
Lastly, does anyone have any shops or fabricators in the CA Bay Area that can do the four link? I can do a lot, but my welding skills and knowledge fall short of a project like this.
Any advice is appreciated. Thank you!
73azbronco
I'm thinking going back with stock fuel tank, be sure it clears.
Jim's Bronco Stable down here in San Jose does stuff like that fairly often.
Another possibility is Deetz Off Road Specialties in Tracy (up in the hills on Altamont Road) who can do most stuff, but not sure if they've done 4-links on Broncos before.
Both have had pretty good feedback over the years.
Jim comes to our Roundup with something cool every year. Would have been another good one this year if we hadn't had to cancel it.
This is what he brought last year:
You can probably get ideas over the phone about what they can do for you (not sure body work is their forté but it can probably be done as well), but I would also wait for more feedback from the members here that have done it. Probably only a couple that have gone to 100" or more, but I bet they're here somewhere.
68rockcrawler
I stretched mine to 98". I moved the rear crossmember and gas tank back a couple of inches. Info in my one ton build thread in my signature line below. I'm on 40's.
H
Huckit36
Thank you guys for the feedback! Paul, I will call those guys to get an idea of what I'm doing and get a plan put together and read through that build thread.
Sent you a PM with Jim's contact info.
You can probably look up Deetz Off Road, but if you need that info I can get that for you as well.
They used to be in Pleasanton but moved to Tracy about 15 years ago or so.
H
Huckit36
Hey guys, another question for everyone. Anyone running trailing arms? Looking for some pros and cons Thanks
Scoop
Bronco Old Fart
Cuchara, CO
I asked the question about ideal wheelbase a while back and 104” seemed to be a good number. The range was about 100” to 108”. I tried for 104 and ended up around 103 1/2”. I added 8 1/2” to the frame, 1 1/2” to the front and then used Zero Rates to get another 1 1/2”. Big difference in how it wheels. I kept the leaf springs. If I ever 4 link I’ll keep this wheelbase. I like it.
Apogee
Tangent, OR
just my $.02, but trailing arms with the coilovers and bypass shocks mounted to the arm are mostly a packaging solution, as you can run a shorter shock and damper to get more travel. The trailing arms also tend to have geometry on their side in terms of stiffness and strength, but it tends to be needed as they're more likely to hit stuff at speed. Very popular with the pre-runner, Ultra-4 and bouncer crowd, but less so on most trail rigs from what I've seen. On an EB, it seems like the c/o's and shocks would be up in the passenger compartment pretty quick, and I'm not sure you need/want that much travel on such a short wheelbase rig.
Tobin
Mdsuits
I was able to get mine out to 106” but I have a 3 link front and a 4 link rear. I also had to remove and rebuild both the front and rear crossmembers. I don’t think there is anyway you could keep the gas tank in the stock location. I used genright offroads 23 gallon universal tank in the bed area. Also as stated above my coilovers had to come way up into the cab area. I ended up closing it back in but it takes up a lot of space. Somewhere after I bought my coilovers already I saw that someone makes a cantilever coilover kit for broncos but I’m sure it is $$$$$$
H
Huckit36
Thank you guys for the great info. How did y’all figure out what size coil overs to put in? I’m thinking I am going to shoot for 101” and do the 4 link
