My son has a FSB with a 5.0. One of the bolt holes for the water pump has some stripped threads in the block . It's one of the long bolts goes for the water jacket. The bolt does not hold. So it leaks . I have tried a new bolt and it still does not hold. So now I'm thinking it's time to try to fix the threads.
My question. Should I use a Helicoil or tap it bigger?
I'm thinking the Helicoil but all the inserts I see are short , like 1/2 long so the bolt will only be grabbing that much thread. The water pump bolt has much longer threads.
What do you think I should do ? Not a job I'm looking forward to.
