Help! Dana 30 knuckle threads stripped
NashBronco
Flowood, MS
I am doing a drum to disk conversion (horsepower LLC) and went to tighten the new spindle to the knuckle and one of the bolts stripped out the threads in the knuckle. I was using my torque wrench and had it set to 40lbs (per directions). It a brand new torque wrench so not sure what the problem is.
Anyone had this happen? Can I tap the hole with a larger bolt or do I need a new knuckle? Any other ideas?
marshall godron
You can drill it out n use a 3/8x2 Allen head grade 8 bolt. Using the Allen head bolt lets you hold it from the back so you can tighten it. The vendors also sell studs that you press in from the back. But there only 1 1/2 long.
B RON CO
Statesville, NC
Hi, you can try to Chase and clean up the threads.
If they are really wiped out you can get a heli coil thread repair from a good auto parts store.
Good luck
I've had knuckles where too many of the threads were gone. Ended up drilling them out and tapping the holes for 7/16 grade 8s. Had to drill the spindle holes as well. Ran for years and did some hard trails, never an issue. Plenty of meat on the bone to go oversize. Just an option that works.
pcf_mark
If I remember right there is also enough room on the bottom for a nut in some positions. Longer bolt and nut would be an easy fix.
Stay away from allen heads - they are harder than grade 8 and break easier. They are strong but not tough.
