Jason72Bronco
- Feb 16, 2015
- 156
Here is generally my issue: a truck that will start and run perfectly, and then sometimes will die without warning and then will crank but not start....followed by starting and running later on. (This post is detailed because I like to put up front as much detail as possible to cut down on back-and-forth questions on things already done!)
Subject: 1972, 302, 3spd. Many new parts over last year and truck has been reliably starting and running perfectly until now. Driven at least weekly. No rats chewing on anything that I know of. (B4 and now pics attached)
Fuel: New tanks and lines. Fuel pump working when running and when cranked. Recent fuel filter, clear gas through filter. Holley 4160 carb. Yesterday I checked and cleaned needles and seats, float levels and accelerator pump. When it is running, fuel flow is perfect. I don't think this is a fuel issue, as it runs perfectly when running and does not stumble or miss or stutter when it dies. It just dies instantly...more on that.
Ignition: Mallory Unilite ignition, Mallory Promaster coil, wires and plugs all less than a year old. Perfectly timed, and when running has perfect spark, no missing, steady idle and acceleration, all confirmed with timing gun.
Starting/Charging: Starter working fine. Solenoid and voltage regulator less than year old. Good battery fully charged reading 12.5v. Good alternator reading 13.8v when actuated. New battery cables, extra ground strap from engine to body. Inspected most grounds with multimeter, and all clean and good.
Possible question mark: Ignition (key) switch. It seems to work fine, but I have not pulled it and cleaned it. It turns on and off and doesn't short out or do anything funny when you jiggle it around. Plus, I'm not touching anything near it when the truck dies. I still get good voltage readings at various locations when turned to "on" position, even during a non-start episode.
Biggest unkown: Almost 50 year old wiring and connectors between all of the above systems! Yesterday I cleaned a few of the main connections with electric contact cleaner (Deoxit) and Q-tips just in case.
So, like I said the truck has been starting and running great since I did alot of work over the last year. Runs so good that I don't hesitate to hop in and take it anywhere, day or night, hot or cold. But one day this week I went to work, and when I came out to go home it cranked and cranked and no start. I fiddled and looked around as much as I could with no tools. Went back inside for ten minutes to call a ride, came back out and started right up as usual. And yes, it has a half tank of gas.
Drove around the block a few times to make sure things were ok before I hit the road home, pulled into a parking lot to look around under the hood while still running, and got back in to go home, still running and idling fine at 180 degrees (normal) water temp. Just sitting there about to leave, and it dies. Won't start again. Decided to get a tow so I didn't just run the battery down trying to crank. Of course, once it was delivered to my driveway it started right up. I let it warm up and began checking things while it was running, and it died when I wasn't touching anything.
Rinse and repeat this scenario several times over the last few days. When it dies it may be going down the road, it may be with me just standing in front of the running engine bay scratching my head, and it dies. When it does die it is sudden, like someone pulled the coil wire. No hesitation.
I was thinking coil issue. I bench tested the coil and Ohms are within specs (.7 Ohm and 12,500 Ohm). I even grabbed my old coil (that still worked when I replaced it) and swapped it out. No change.
Now this next test is odd to me, and I know that voltage at the coil can be odd since it is one big transformer. With key in "on" position and not running, wire going to coil (disconnected from coil) is 12v. When connected to coil, (+) terminal reads 4v. When it is running and all wires connected, voltage at coil (+) is around 9v. Again, I know voltage readings at the coil terminals can be funky but is this normal? Reading at the brown wire on the starter solenoid is same. When key is "on" around 4v, when running, its around 9v.
Based on issues I've had with other old cars, I suspected a possible ground issue. So, I added a ground strap from the engine to the body, and all ground connections I could fine were great. Plus, it dies whether it is moving and jiggling around or just sitting still in the driveway, so I don't suspect just a loose connection.
Also, I substituted in a coil wire, looked around under the distributor cap and rotor for anything odd or broken. No change to condition.
I tend to use the word "random" sparingly, because there is almost always a reason for everything. But this issue does not seem to be related to moving, not moving, temperature hot or cold, sits overnight or sits for a few minutes. I'm in a good mood or not. So far its just random.
So any help in what to test/do next is greatly appreciated in advance. (Of course, as with any intermittent issue like this, I won't know when I can do a test when it is running, and when I can do tests when it is not! It's up to the truck.)
And no it is not for sale. Yet.
Jason
Jason
