ugly74
Bronco abuser
- Apr 17, 2006
- 2,847
Hello everybody!
I’m having problems with my blue connector duraspark module.
I installed this with my 302 years ago, when my unilite took a dump, and it never missed a beat.
I just re-installed my 351c, and I simply robbed the guts from the 302 dizzy and put them in the Cleveland dizzy, and ran the duraspark like before.
Then the module failed. It would spark only right as I was switching the key off, but not as it’s cranking.
I replaced the module (Autozone part) and wired it up, but this time added a 1.3 ohm resistor between the module and + side of the coil. (Never had one before)
Fired right up! Sweet!
It ran for about 20 minutes, then I took it for its maiden voyage. About a mile down the road, it did it again. Module is hot to the touch, and it only sparks as I’m turning the key off. Same as before.
It’s wired the exact same way it’s always been (except now with a ballast).
Can one of you gurus lend me some clues?
