Subwoofer, advice needed
DonsBolt
Chestnut Hill, Mass
Hey guys while cruisin yesterday a awesome song came on the radio, so I cranked it up, while it sounded good, it was missing the bass to make it perfect.
So I have decided I want to put a small sub under the passenger seat.
I have a 100 watt mono amp I was going to use for another project a few years ago. Just don't know if it is the right type of amp for a sub.
http://www.xtant.com/archives/html/products/xtant1.1i.cfm
For the box I am thinking of making a 13x11x6 inch sealed box out of 5/8 mdf. Mount it under the passenger seat, and have the sub fire upwards.
This is the sub I am thinking of using
http://www.crutchfield.com/p_1366W3V34/JL-Audio-6W3v3-4.html?search=subwoofer
My head unit has a sub output on it, since the amp is pretty small I should have no problem mounting it under the drivers seat, or since I got rid of the heater duct, and welded the hole shut, maybe on the kick panel on the passenger side
So do any of you audio experts think my plan is sound, do you recomend any other small subwoofers, and does this amp sound like it will power that sub, and sound right.
I am open to any sugestions, as I am not really a audiofile in any way
rekoj71
I'm not the biggest expert on car stereo installation but I have done several.
I like the woofer. It should sound nice and crisp. It's not going to shake your vehicle to death and won't be heard a mile away while playing gangsta rap, but if you are a rocker 6" and 8" woofers are great.
The amp will probably work but it would probably leave me wanting more. It won't be able to really push that sub to it's potential. It's more of a full range designed amp and 100w is plenty for full range speakers but the specs on that look lower than I would like. Most car stereo installers will tell you that more subs are ruined by trying to push an amp thats too small at it full output capabilities and sending a distorted signal to the sub rather than by using an amp that is rated higher than the peak capacity of the sub and throttled back a bit to allow it to send a good clean signal to the sub. If I were going to use that sub I would probably use a minimum of a 200w amp and probably actually use a 300w amp.
The sub output on your deck does allow you to use a full range amp without a crossover as the sub channel in your deck acts as one but sometimes amps designed for subs are fairly cheap anyways as they don't have to be designed with perfect accuracy as low base frequencies are usually pretty distorted anyhow. You also only need one channel in sub type frequencies (which is why you only have one sub output in your deck or even in home stereos) because low frequencies aren't separated into left and right stereo. Hope this helps ya. (or anyone else looking at this)
DanWheeler
Kirkland, WA
for the amount of money and effort your going to put into making a little 6.5" sub work in your truck it seems like it would be a lot easier to get a bazooka tube.
anything less than a 10" sub sounds disappointing if you ask me. I prefer a 12 to be able to hit the low bass notes. I listen to all types of music and a nice 12" sub does wonders for all genres.
I just picked up a 12" Alpine Type-R driver in a very nice enclosure with a 800 watt Pioneer mono amp for $150. The seller thought the amp was busted but it was his car or his wiring.
There's so much car audio equipment being bought and sold on craigslist it's practically a commodity. Wait around and you'll find a good deal.
22213evl
Rio Rancho N.M.
I run a 10" kicker sub in a ported box behind the back seat, with a MTX 210 watt amp under the pass seat. it gets plenty loud and thumpin. you can't really hear it bumping to hard outside with the top on but it rocks on the inside, running a 50 watt sony cd head unit.
DonsBolt
DonsBolt
Chestnut Hill, Mass
Thanks for the advice guys
I am really just looking for some fill bass, and would like to keep the box as hidden and as stealthy as possible. Thats why I decided against a Bazooka tube, I have used one in the past, it was great, but just no way to hide it in my Bronco.
I didn't think of checking out craiglist, but your right looks to be a good place to find a deal.
DonsBolt
DonsBolt
Chestnut Hill, Mass
Yo guys
Talked to a tech a JL today, he gave me a few ideas, so may have a slightlly new plan
Since I have about the worst center console, I may make a new one, and put the same JL 6.5 inch sub in the front. Would also make a good place to mount my little AMP.
He knows the AMP I plan on running, and tells me it is just about perfect for the 6.5 inch sub I want to use.
So here are two drawing I made, the first one is a rough scetch of the console, the 2nd one is a calculator I used to figure out the internal cubic feet area
22213evl
Rio Rancho N.M.
Yo guys
if you build it the bass will come
looks good, get busy and rock on
SloppyDawg71
Cedartown, GA
on your box, just make sure that you coat it with something like roll-in bed liner-the best boxes are sealed that way and it will make a world of difference in a box that is just "seam sealed"
Dan's73
I drew one up a while back to go under the rear seat.....single, shallow mount 10 or 12" sub, with enough room for the amp to mount next to it. I used the online calculators to determine the appropriate size/volume for the subs and there's plenty of room under there for a good box & amp (assuming you have a stock rear seat like I do). One day I'll build it......
DonsBolt
DonsBolt
Chestnut Hill, Mass
Thanks now I just have to find some 5/8 MDF, can find plenty of 3/4 inch
Ready to Rock
Thanks for the tip ;D
My plan is to get rid of the back seat, going to a half cab eventually
PaulT
Wilton NEW HAMPSHIRE
I tried the link to the sub this morning and it wasn't working (crutchfield issue).
I was just about to say your box was much bigger than what they recommended for the sub, but looks like you've got it all figured out Don.
DonsBolt
DonsBolt
Chestnut Hill, Mass
Hey Paul it is the
JL Audio 6W3v3-4
here is a quote from the sizing info
Recommended Sealed Box Volume: The sealed box size recommended by JL Audio is 0.15 cu/ft. A diagram is provided in the owner's manual for a sealed box with external dimensions of 9" W x 9" H x 6.75" D, assuming 3/4" thick material. (If you are using 5/8" thick materials, you should subtract 1/4" from each dimension.)
matt w
Ya, I have a Bazooka tube with the amp built in and it ROCKS! ;D ..it won't fit under your front seat though!%)
daveweil1
Savannah
I agree with Dan Wheeler. I've got a 12" Kicker L7 Solobaric (the square one) on a Audiobahn 400 watt amp and it rocks, even with the top and doors off. The box is bolted into the bed, then I screwed 2 steel U barckts across the face of the woofer with tamper proof screws.
daves bronco
Bonney lake WA
I have done a car stereo in every car I have owned, 2000 watts to 200. It sounds like for what you want it will be perfect. maybe later you will find you want a little more power, = bigger amp or deeper bass=bigger sub. but the great thing about jl is you can turn around and sell it later. be careful when you set you gain, if you are running you other speakers of you deck or the sub might over power them all the time. decks only have about 20 watts max rms. One thing about your design is that you can see the sub, thevies know where there is a sub, there is a amp,and subs dont get muffeld that easy like normal speakers. So maybe you can redisign your box to hide it and the amp better. there is a million different ways to build a box it dosn't have to be the standard way.
BamaBronco74
I have been doing cars tereo in all of my cars myself for about 15 years, i would reccomend AGAINST the center console idea, as well as 5/8 MDF. Every proper box should be 3/4 MDF (in larger subs for sure) to reduce flex. If you do the center cnosole, fil with polyfill (pillow filling) and you will probably get a few more Hz lower bass response, overall warmenr bass. 5/8 might be ok in your case though since you are really using a midbass/woofer, instead of a true woofer.
lonesouth
I agree that size matters. That 6.5 will indeed fill a void, but I don't think it will rock out. In the past I have used an Infinity Kappa Perfect 10.1 in a .22 cubic foot box and it sounded great. It was no replacement for a 12, but was much better than stock. For the effort, I would encourage you to run a 10 and just throttle it back a little. I feel it is almost always better to over build and under drive.
A note on installing. I have always found it useful to run a switch in-line on the power signal to the amp. This will allow you to cut the sub off completely for times when the sub just isn't required. Like lots of times i will be listening to the latest pop/rock with a solid bass line, and then switch to country. Country I found has really heavy bass that will drown out the song if played through a sub. All of my installs have been with stock systems and only adding a sub, so YMMV.
DonsBolt
DonsBolt
Chestnut Hill, Mass
Thanks guys
My head unit as a sub level control function, so I can allways turn it up or down with the head unit. Also I don't listen to country, so no need to turn it off, hehe
I could allways do some black speaker fabric over the sub, then cover the rest in vinyl so it woulod be hard to see the sub.
Still think I will either do the console, or maybe go back to my origional idea and go under the pass seat.
