- Joined
- Feb 24, 2002
- Messages
- 10,872
Your 2 idle mixture screws turn them in until they lightly bottom out. count the turns going in so you can set them back after you remove the screws. now remove those screws. spray carb cleaner those holes using the carb cleaner with the tube attached. Don't go crazy with it just a couple of quick blasts now screw the screws back in all the way and then back out each screw the proper turns you wrote down. You could also have problems with a leaky power valve in the carb Have you had any back fires through the carb? always search for vacuum leaks with an idle issue.
