Swapping 3spd for a C4, Need HELP!
rookiebuild68
I'm sure if I was a computer guru I would find all the info needed on here, however I am not. I am looking for a write up on the complete process of swapping out the 3 spd for a C4. Can someone help?
Viperwolf1
electron whisperer
Here are the basics.
1) Remove starter and everything from the crankshaft back.
2) Remove pilot bearing.
3) Remove clutch linkage and pedal.
4) Install auto blockplate and flexplate.
5) Install C4/D20.
6) Figure out a way to shift it.
7) Wire in reverse lights/neutral safety switch.
8) Hook up the kickdown rod.
9) Install auto starter.
10) Install trans cooler and lines.
11) Add trans fluid.
Madgyver
Bronco Madman
it helps to have a complete donor EB..
Welcome to the site.
ryoungbronco
Belmar, NJ
That is what I did. I found a truck for $650 complete. I was able to have all the necessary parts for the swap and after parting out the parts I do not need I should make my $650+ back. Any additional money made will go toward the rebuild of the C4. Good luck.
R
rookiebuild68
I think that I have almost everything I need, except the linkages for kick down and shift. Found an auto column but didn't have shift linkage. Does the Carb. need to be changed out for the kick down linkage? Thanks for the help! You guys make it sound so simple.;D
ryoungbronco
Belmar, NJ
You don't need to get the kickdown that is original to the bronco. There are aftermarket cables that will work. The carb will need to get the linkage for the kickdown, again there are aftermarket items for this too.
David Smith
David Smith
Recently did 3-speed to C-6. Lokar has the best kickdown set-up. Complete with throttle cable while your at it. Linkage bracket mounts on the carb, gets rid of that old rod linkage. Much worth it!
