T-case shaft???
NC-Fordguy
Bethel/Greenville NC
Guys...
I'm replacing a dana 20 with another dana 20. How does the output shaft come out? providing that's the right term, in other words the shaft that goes into the intermediate housing. The replacement t-case does not have a shaft on it and I had planned on using the shaft in the existing dana 20.
I'm thinking there must be some sort of snap ring???
Ed
Yes, the spud shaft comes out along with the bearing and retainer. They often get stuck at the O-ring. If I remember right, removing the output shaft gives you a place to drive the spud shaft out, no snap rings to deal with. Just a stuck O-ring.
I hope both T-cases are the same type. I know they changed gear ratios and that may be an issue using an input gear from 1 trans into another, unless they are the same ratio.
NC-Fordguy
NC-Fordguy
I"m replacing a j-shift case with a t-shift case...are you saying this will not work since they are different gear ratios? 2.46 on a T and 2.34 on a J if I recall correctley?
Ed
