BroncoinAlaska
Got the EFI running as well as I thinking can. Swapped out a lot of sensors and have no codes besides EGR. The engine still runs off and occasionally sputters and has a lack of power.
SPECS:
347 Ford Racing block
185cc aluminum heads
Trick Flow upper lower manifold
75mm BBK TB
70mm C&L MAF
24lbs injectors
BC Broncos headers & 2-1 exhaust
Explorer Serpentine system
A9P computer
Ryan's Harness
BC Broncos EFI fuel lines AN
BC Broncos 23 gallon tank 155 Lph pump
I have talked with the closest shop that can dyno tune Ford 5.0's. Just describing the setup they said they can tune the Bronco. They recommended that I replace a few items.
New distributor - I was thinking MSD pro billet?
Fuel pressure regulator - Aeromotive
Fuel rails - Aeromotive or Trick Flow???
I can see the need to replace the fuel pressure regulator. The fuel rails I have no idea about. I thought the stock rails were good until super high horsepower.
What other parts should I replace to get the most out of the tune?
I would like to get this back on the road every day!
SPECS:
75mm BBK TB
70mm C&L MAF
24lbs injectors
A9P computer
Ryan's Harness
