Terra Low Nightmare
NC-Fordguy
Bethel/Greenville NC
Guys.....
I'm in the process of rebuilding a J-shift dana 20 using the terra low gear set
Come to find out the instructions are calling for a manual tranny with a six spline output shaft. Will this kit work for a c-4???
Secondly while going through the parts I figured out the gasket kit is for a jeep 20. No big deal as I can get a gasket kit from napa. Now I'm wondering if this gear kit is for a jeep dana 20. The gear sets seem to mate up with the shafts but I'm concerned that these are not the right parts.
Any advice on determing what this kit is actually for?? It's labled for a bronco dana 20 and does have instructions for a bronco
trailpsycho
Cant speak for the kit you received, but everything was there that I needed for a complete rebuild other than the bearings. There will be extra gaskets though... They also dont supply shims as I remember, but the stock shims should get you pretty close.
Here are some pics of the Tera Low kit I received. Gotta love that price!!
PLEASE NOTE:
The last 4 pics are of the WH D20 DELUXE rebuild kit. You can see from the photos by close comparison that the seals and gaskets are the same. WH throws in the shims and some extra stuff for a super nice rebuild...but for the most part other than the bearings the TL kit has it all. I have enough gaskets and seals to build another 20 left over between the two kits...and now I have the bearing PNs as well. Again, I cant speak for what you ordered or where you got it from. My guess is, however, that there isnt much difference between the D20 kits...hence the extra seals, gaskets, etc...but I have never seen or taken apart a Jeep 20.
There is a stub shaft. 28 splines for the transmission, 6 splines for the gear to attach. There is no reason it won't work with the autormatic.
You did order the Low20B? the "B" part specifiys that it is for a Bronco application. I think a lot of the instructions are generic to Jeep applications. the Jeep people need all the help they can get.
trailpsycho
Yes, throw out their instructions...they are for a Jeep. Download or print the PDF on here for the D20 rebuild and just substitute in the TL gears for the Bronco gears. It really is fairly easy. The most frustrating part will be the set screws on the shafts...especially if you have larger hands...otherwise its pretty simple. Good luck.
Here you go: http://www.classicbroncos.com/dana20/dana_20_manual.htm
70_Steve
Old Guy
trailpsycho beat me to it. The instructions that come with the LOW20B are useless, and misleading. Just rebuild the tcase as stock using the link trailpsycho provided.
For the setscrews on the shift forks, I made my own allen head socket. I cut about 1" of an old allen wrench that fit those set screws. Then stuck one end in a 1/4" socket with some RTV.
bigmuddy
Marthasville Missouri
having never rebuilt a D20, are there set screws for both the J and the T shift? If one of the set screws backed off or broke, would that allow a shift rail to rotate?
Ben
Ben
The setscrews lock the shift forks to the rails. If the screw backed out (doubt you could ever break one) then the shift rail would no longer be attached to the shift fork and it could do just about anything it wanted to within the limits of the shift interlock pills.
The rails and forks must be 2 pieces. There would be no way to assamble the transfer case if they were not.
Viperwolf1
electron whisperer
Ben
Yes especially on a J-shift. A T-shift would have the rails connected together. I like to use Loc-tite on the set screws. I've seen some backed out before. Makes it very difficult to shift.
bigmuddy
Sorry to hijack but a member here had his twinstick stop working after a day of wheeling, which turned out to be his shift rail was rotating within the housing. I am wondering if this is due to a set screw backing out. Not sure if he has a J or a T shift case?
Thanks Ben
Viperwolf1
electron whisperer
Thanks Ben
The only way the rail can rotate is if the set screw has come loose or the shift fork is busted (unlikely).
cracker
Pueblo, Colorado
I just added the TERA low to my T-shift. Ditto, throw away the intuctions! I tried dto follow them, and was more confused. if you are any kind of mechanic, then you can rebuild it it less than one hour by yourself.You should have all of the seals that you need and extra. A long allen wrench and/or socket allen will reach the shift rails without any problem.
NC-Fordguy
NC-Fordguy
Update...
Seems that I have the jeep dana 20 re-gear set. Called terraflex and got them to tell me what is what. The difference being the gasket and seal kit and one of the five gears. 4 of the 5 gears are used in both kits with the 5th being the difference.
They are going to send me the gear and gasket kit but it kinda sucks having to wait.
Is it just my browser, or is anyone else having problems seeing the pics on the dana 20 manual? Got a bunch of x-outs
ManTruck
I am happy with my Tlow upgrade and have had no problems. Just used the manual in the link and was easy to redo. The advise shared by all above is good advise. Just take your time and keep the printed documents on the bench with you.
70_Steve
Old Guy
At least you did figure out what's going on.
In another t-case thread recently, someone mentioned that they could not see the pics using Firefox, but were OK when using IE.
Buldozer
Bronco Virtuoso
God's Country
Did you find those gears cheap anywhere? The regular bronco suppliers that have them are priced fairly high it seems.:eek:
iwlbcnu
I have them behind a C4, didn't do the rebuild though.
