Death Wobble and a fix
I dont know if any of you guys have experienced death wobble before but I've been struggling with it for a while and it sucks. I have a number of potential factors that may be contributing so I've gone through a lengthy process to try and narrow it down. I've read alot of posts on many sites trying to get information and its been pretty helpful but ultimately I had to try a bunch of stuff to get it right. I can tell you this though. There's two factors to most death wobble problems the thing that starts it and the suspension that lets it keep going(not including jeep Y steering). Ultimately if you fix the the thing that allows the front end to slide back and forth then you cant actually get death wobble. Unfortunately, as was in my case, that may only be possible with a heim joint on both ends of the track bar and then some more fab work on top of that.
So heres the specs of my bronco that matter. I have 9 degrees positive caster and 5 year old 37" m/t's. I run Currie Currectlink steering joints and I have Johnny Joint ends on both sides of my track bar. My track bar is slightly shorter than my drag link but runs parallel with the drag link and is almost flat. Also I get zero bump steer so all in all its a good combo. This may take me a few posts to get through the whole process I went through but I did fix the death wobble. When I first put this all together and up until recently I never had death wobble. Although I did get some random "bump" that was just wierd feeling but never really did it consistently or cause any other issues so I left it alone.
When I started having death wobble I went underneath and had my dad turn the steering wheel back and forth until I could find the movement somewhere. Since death wobble, at least in a bronco, is strictly related to the front end being allowed to move back and forth on its own I knew it had to be associated with the track bar. What I found was a lot of deflection at the top johnny joint. So i replaced the johnny joint with a new one hoping that would fix the problem. Unfortunately it didnt fix it for long. Although the first couple days it worked well. So step two was to put a heim joint on. My thought process at the time was that the upper johnny joint was smaller than the lower joint because thats all that would fit in the bracket and maybe due to the weight of the diesel etc etc that the joint was just undersized.
I needed to adjust the track bar anyways so it wouldnt hit the oil pan during articulation so this was a good time to do it. So I reworked the track bar and added a heim joint.
That once again felt like it worked for a day or two and then back to death wobble. So it wasnt the Johnny Joint after all! Which I guess isnt surprising since I had called Currie at one point and they didnt think that was the cause. They also told me that they had done extensive deflection tests and their Johnn Joints deflected a lot less than stardard urethane bushings. So theres that and now what?
After crawling back underneath I searched around some more and found that the bolt on the top that holds the track bar mount to the frame was a little loose. So I thought "hey alright I got this". So I thightened it up and then I welded it to the frame so it wouldnt move.
Once again same damn thing. Felt great for a couple days and then right back to it. I went back and checked my weld and it was fine and the heim joint wasnt flexing so it wasnt that. So I headed down the track bar to the front end mount. As you can see the track bar mount i made is about 3 inches above the knuckle and it sticks out a few inches as well to clear the coil spring. The factory bronco track bar mount and drag link connection point is set to the inside of the coil spring where there's room so when I went to the 1 ton Currie fabricated frontend it brought some challenges with it that I thought I had worked out
But after having my dad move the steering around as I watched and felt around I couldnt see the track bar mount flexing so I assumed the only think left was the Johnny joint. So out with that and in with another heim joint. I gotta say heim joints are expensive! Since the axle side of the track bar had a johnny joint with threads i was able to just screw it in so that made life a little easier.
After I got it in I went for a drive and immediately noticed that it was not better. When I pulled back into the driveway I noticed that my steering wheel wasnt straight. Back underneath I went and I found the next weak link in the chain. The track bar mount on the frontend. So at that point i had no choice to fix it. At this point I didnt know how to fix it because to fix the track bar correctly I would need to get it closer to the knuckle but that would mess up my paralled arms and potentially cause bump steer. Clearly theres just too much leverage that the track bar has on the mount. I also started doubting my understanding of death wobble. Could it be the tires? Is it possible that no matter what I do its possible that I wont be able to fix it? So I got back on the forums and the interwebs trying to figure out what could be causing this.
