thermostat/goose neck leaking- help!
Bundy
on the 302, i am trying to put a new t-stat in but everytime i finally get it in it leaks. it's a Coolflex radiator hose that connects to the manifold and when i took it off intially there was just this o-ring.
the o-ring doesn't appear to be in bad condition, is there something i am missing? i tried running it with the regular 302 paper gasket and the o-ring, but that leaked too.
any ideas? also any tricks to getting that damned t-stat lined up/in the right position or just alot of swearing etc?
Viperwolf1
electron whisperer
Get rid of the o-ringed water neck and get one that uses a real gasket.
1970mule
also i had that problem not to long ago, do u have a aluminum intake manifold? if so maybe one of the screw holes are stripped? and it is not tightening all the way down.
Chrome thermostat housing with O-ring?
If so get rid of it and get a normal thermostat with a paper gasket. Those O-ringed chrome jobs always leak. I can't think of how many of those I have seen with massive amounts of silicone around them trying to seal them up. Sounds good on paper. I never reearched it but I think the housings warp and can't maintain the pressure needed to seal the O-ring. But a large flat paper gasket weals just fine with a normal housing.
charvey9
Beaverton, OR
I had this problem recently too, and found out that the thermostat was slipping out of position each time I tried bolt the water neck back on and caused the rubber seal to leak.
The last time i put it together I used high temp instant gasket sealer on the T-stat to hold it in place and it has worked fine ever since.
blubuckaroo
Grease Monkey
Ridgefield WA
Get an origonal equipment gasket style housing. Check the housing gasket surface with a straight edge. They get warped when overtightened. You can flatten the surface satisfactorily with a fine flat file then finish with emery cloth on a flat surface. Make sure the bolts aren't too long and bottoming out preventing the housing from pulling up tight. A bit of gaskasinch on the gasket to hold the gasket and thermostat in the housing while youre assembling it and you're set.
SteveL
Huge chevy guy
Hawthorne ca
those chrome aftermarket housings suck. Like stated above, get an original replacement and you'll be fine.
fordguy
exactly those o ring jobs are worthless ask me how i know. i threw the one i had away.
toddz69
One trick I learned recently for holding the t-stat in place is to loop a piece of dental floss through the t-stat and hold it tight while you're installing the housing and tightening the bolts. Once they're sufficiently torqued, just pull the dental floss through and you're good to go.
I had a leaking t-stat housing about a year and a half ago that no paper gasket seemed to fix. I ended up using the Permatex product for sealing it up and it held for about a year before it started leaking again.
I ended up spending the big bux on a nicely machined aluminum neck (Billet Specialties) with the o-ring and so far (3-4 months) it's holding just fine. If it starts leaking again, I'm going to replace my manifold :-[ .
Todd Z.
Bundy
Bundy
haha, i love the fact that i can come on here and post something lame the PO did and have at least 5 people with the same story.
funny, the guy at Orange Engine also snickered when i asked him for the o-ring and he mentioned what a POS the chrome housings were- he also suggested the standard housing.
for now i just used a thin bead of rtv sealant and it's holding for now. for sure replacing the housing before any big trips.
Jeff10
Indianapolis
Hey blubuckaroo,
I'm fighting with a leaking thermostat housing. I have tried a little RTV on both sides of a paper gasket initially, and it leaked. I tried nothing but the paper gasket and it leaked.
I read your post about the Gasgacinch, and looked online at the product description. Are you still a fan?
I suspect that the thermostat is moving slightly. (Using the RTV was the poorest result. I searched this last night in other boards... opinions ranged from no RTV to RTV only to RTV and paper.)
I'll look for some Gasgacinch tomorrow.
Jeff
savage
Bronco Nut
Renton
Mine was leaking on my 302 and it ended up being the bypass connection on the thermastat housing,the steel part thats pressend was leajking so I bought a new 3/8 connection and put sealer on it and pressed it in where the old one was,no leaks so far.
Jeff10
Indianapolis
Hi,
I purchased High Tack Gasket Sealant by Permatex. I used the sealant on the gooseneck side of the gasket. That held long enough for me to install the gooseneck without the thermostat moving. The gooseneck isn't leaking at the mating surface, although a couple of the new hoses are weeping a little and need to be tightened.
The High Tack seemed to work pretty well.
Jeff
savage
Bronco Nut
Renton
Ive been having trouble with the housing on my rebuilt 302.Ive tried different houseing from murrey brand,to Mr Gasket and have had no luck they all have leaked.Im thinking of retrying my old one,Ive read they make a sealent just for this issue but I cant find it.Has any one hurd of this sealent?Im stuck on how to fix it.I have a new EdleBrock manifold and the face is flat so you would think it should have a good seal.
ransil
For holding gaskets I use yellow weather strip adheasive ( aka monkey snot)
baddad457
Nest time you take it off, take a piece of rough sand paper and rough up the chrome finish on the gasket surface, then use a gasket, place the T-Stat in it's recess, smear a thin coat of RTV over it, then place the gasket over the RTV. Then bolt it back in place. It's not the housing that's the problem, but the chrome. It's too slick to get a good seal with anything. If it's an O ring housing, fill the O ring groove with RTV when you apply it, then enough RTV to make the gasket stick to the housing
