hey guy bin a while i posted something.anyway my 69 bronco 5.0 is getting tired.got alot of blow by out of pcv,she leaks from every gasket.when i jam the gas its like a cropduster plooming smoke and not to mention makeing a mess of engin bay.so if im gonna swap to a mustang 5.0 i hear the 86/89 5.0 ho motor is what i want.just want some info from u guys.and is the swap easy if i buy a hole car cuz then i have everything whire,computer,etc.thanks
You have many options, and a few things to consider. Mustangs make great donor vehicles. The best option is an 89 (or newer) mass air donor, however, speed density will work fine if everything is staying stock. The Ford Explorer is another great option, but you want a 96-97 as they do not have the GT40P heads. Those heads can cause header issues. They're fine if your using the stock manifolds.
Some are using the Explorer harness, others using Mustang. If you use the explorer, make sure it doesn't have the PATS system. The cost to convert will run between $500-$1000, and can go as high as $3000 if you buy the higher end parts. I'm going to suggest that you use an in tank fuel pump (modify stock tank) Rework a Mustang harness, and use an A9p or A9l ECU (autozone has remans for $120 or so)
