Have always wanted to do the famous Rubicon trail and finally have the Bronco in pretty good condition to consider it. I did the Dusy Trail back in 1994 or 95 and other than running rough due to hi elevation she did pretty good.
Here's a build list:
74 Bronco roadster w/ D44 w/ Yukons (bought Yukons in 05 before hearing about some problems they have) and Spicer u-joints and 9" w/ stock 28 spline axles, detroit lockers f & r, 4:56, Stak mini 3 speed, new drive shafts, rebuilt 351W w/ carb new holly TA, triple pass radiator, rebuilt C4 w/ 2 trans coolers - 1 cooler does not get much flow unless moving and one with Tstat and electric fan that runs alot on trail. BCB 3.5" lift w/ super old (1994) BFG mud terrains, only bikini top, new alternator, new dephi p/s pump, rebuilt p/s box, accessory wiring new, stock wiring for all else but seems good, 23/24 gallon tank, 1/4" rock skis, hi-lift, old school smittybuilt bumpers.
Here's what I am thinking to add to Bronco:
New tires, most likely BFG's. Not sure to go w/ 33's or 35's. Like to drive a little fast in deserts so wanting to keep Bronco low as possible, hence possibly staying w/ 33's. Spare tire rack w/ full size spare and rack for quick air tank. Putting stock side tank back in for 11/12 gallons more. Fan on trans cooler w/ manual switch. Bump stops, check rear shocks - seem to be limiting travel, tends to pull tire off ground when flexing, may need better than stock rear mounts. New track bar bushing, P/S box reinforcement plate, bring spare track bar, f&r spare driveshafts - would have to pay to get mine to correct length, change all fluids.
What other hard parts and/or additions/upgrades would be needed or considered? Any ideas are appreciated.
