Upgrading my 9” to 4:11 gears. It is a 1969 with factory limited slip. Cleaned and inspected, replaced all the bearings, set the backlash at .013” and have about 15 inch pounds of preload on the input pinion. With all the shims removed the wear pattern is from center to toe of the ring gear teeth on the driven side. Am I doing something wrong? Suggestions? Side note: had to clearance the unfinished edge of the casting in the area of the inner pinion bearing in order to achieve the backlash without having the teeth of the ring gear contact the housing. Thanks!
