Third member question....:)
Good Times
Wenatchee, WA
Is there a difference between the third member in a 1974 bronco VS a 1976 bronco. I'm looking on Detroit locker's web site, and they have a part # listed for the 76, but not for the earlier years. I think the carrier bearings are the same, but I'll defer to the experts on this site.
Thanks.
vuke
Red Bank, NJ
should be the same. Pretty sure a 9 inch is a 9 inch no matter the year. As long as the spline count is right you should be good to go.
Crap. I just had a whole dissertation going on where I was speculating on every possible reason for them not listing one. Then I remembered that I have my old Detroit (Trachtech) book! Oy.
So, my listings show a unit for the 9" up to '74 with a 1.62 bearing hub diameter. It's number 187S-13B for 28 spline axles with a 1.20" diameter.
Next up is the 187SL-13A for the 9" up to '79 with 28 splines.
The one you're referring to is probably the 187SL-17B which is a 31 spline unit. That's no doubt why they only list them from '76 on. Most likely that's the first year that Ford used a 31 spline unit. Sound reasonable? I thought that some cars got them farther back than that, but maybe not.
Those last ones don't specify a bearing diameter or anything else, other than it doesn't work with the 2.72 gear ratio. Which, obviously, most of us don't have to worry about.
Maybe the others are not listed if they don't make them anymore? Would make sense not to have one with the 28 spline axles. With the ready availability of 31 spline axles, it makes sense to upgrade instead.
Oh, and if the numbers that you're finding don't use the "SL" in the middle, it's probably the same thing. At the time that stood for "soft-locker" which was after they bevelled the teeth to soften up the lockup bang. Don't know if it worked, but it was good for marketing after the Lock-Right (LA Locker) came out and claimed a softer lockup than a Detroit.
