Third times a charm v3.0
JSmall
JSmall
Jaromy, Bro dude! I am floored by your progress. I remember when you first bought this... down in Roseburg, right?
That is amazing work, your are at the top of my Bronco Guru List.
Rock on dude! :cool: ;D
You’re correct ;D
I remember driving it up in the mountains with you guys and it didn’t make it home. Battery, alternator or something like that. I’ve learned a lot along the way.
Far from a guru ;) I ask lots of questions to the right people
jmhend
Finished up a rebuild on the 4R70W that I will be using. I'm in the process or ordering all the parts needed to make the swap. Atlas time!! :cool:
Currently working on my roll cage to add the floor bars and a harness bar for the PRP seats that I won at NWBR this year.
Going from a manual to an auto? What manual did you have?
Second question: what are the two holes in your doors just below the mirrors for?
JSmall
JSmall
Going from a ZF 5 speed.
Those are the holes left over from the bigger truck mirrors. I added some button head screws to clean it up a little.
JSmall
JSmall
A few more pieces showed up that are needed for the 4R70W swap :cool:
I have always liked the Switch Pros so I decided to remove my rocker switches and replace them with these. I am planning out how I want to lay out all of the wiring right now.
I got the floor bars installed for the new seats. Maximum clearance in all directions has always been a priority with the cage build. I decided to add some offset into the bars to continue with that theme. More work for 1/2" more clearance ;D
jbawall
Edgewood, Washington
I am intrigued by the switch-pros. I have been reading their website and watched a few install videos for the last half hour...
Probably should do some actual work...
JSmall
JSmall
dayuuum Jaromy , some good looking parts right there
I hope I can get some Moab dirt on them soon. Thanks ;)
flange mount front shaft?
1300 Series flanges front and rear. I will be using 1350 all the way through
I have always liked the idea of having switch panels and these should work great. Get to work ;D
Yeller
Rogers County Oklahoma
The switch panels are really nice. They save so much wire and so easily configured and changed in the future. I’ve been contemplating putting one in mine for a light bar and a few other farkles.
JSmall
JSmall
Mmmmm...farkles ;D Should be a nice addition
Very Nice!
Everything, but really like the switch pro's :cool:
They are pretty cool. If my dash/console turns out the way I have imagined it in my tiny brain, it should look really good and be functional.
JSmall
JSmall
Not 100% sure yet. I know they will be mounted in the console within arms reach while strapped in. Probably something simple like this or maybe add a little angle to them so they are even easier to see.
JSmall
JSmall
This is my plan for them right now. The good thing is I will be able to easily modify or change my mind if I want to configure them differently.
jmhend
I wonder how easily the 3M tape comes off (thinking it could be good and bad if they are really sticky. :eek:
I am super interested in seeing this center console
Did the PRP seats come with heaters or did you have to add them?
JSmall
JSmall
3M tape? Not sure where there is tape.
I ordered the seats with heat so I didn’t have to take them apart.
.94 OR
Willamette Valley, OR
In the picture, your switches have the possibility of being hidden behind a beverage vessel, which could be an issue.
My wife has an Explorer with touchscreen controls mounted on the dash angle. I hate it as there is no support for your hand and the "button" needs to be pressed with the fingertip/fingernail almost and not the pad of the finger if the "switch" was at a shallower angle. It is also read hard for me since I don't drive it daily, to keep my eyes on the road while trying to make adjustments for anything.
Are the back lights for the switches dimmable?
JSmall
JSmall
Makes sense. My console will be set up differently and the cup holders will be at the rear and the panels will be towards the front. That’s the plan right now, but that could change. I need to find room for the Winters shifter and cable shifters as well.
