Third times a charm v3.0
GloNDark
Man this is a good looking build. Can't wait to see how those shock towers/inner fenders/rear seat turns out. I want to 4 link the back of my 73 so bad but the rear seat has stopped me. Now I'm thinking it's possible.......hhmmm
JSmall
JSmall
I wasn't sure myself, but now I believe it is possible. I gave some dimensions to my brother and he made a rendering of the inner fenders. I'll send the file to a shop and have them cut out soon. I will end up boxing in the strut towers.
miikee73
Shadetree Guru
Aloha
Lookin good, that's what you call progress. Won't be long and you can move your thoughts to the front. Will the front be as involved as the back?
JSmall
JSmall
Thanks Mike! I loaded the axle up so I can take it to the powder coated on Monday. I put the front under the Bronco today so I can get started. The front is more involved, but I learned a lot on the rear so I'm hoping it goes quicker.
badmuttstang
redneck grease monkey
Definitely making a lot of progress bud and it looks great let me know when you get the wheel tubs. Did you decide not to go with the ones Andrew had?
JSmall
JSmall
I sent out a few emails requesting quotes for the fenders my brother created for me. I think replacing the full wheel well will be easier. I'll let you know.
JSmall
JSmall
Cool sounds good
I was able to get them cut out and they are being bent up today. I'll be in the garage all day on Friday getting the rear installed and then moving on to the front. Come over if you want to hang out.
JSmall
JSmall
I got the steering box moved forward a few inches. I will be able to finish it up when the Bronco is on the ground. The bumper is in the way and can't remove it because it is sitting on the stands I built. 1/4" plate on both sides with DOM sleeves between the frame.
To get the 5.5" up-travel I wanted, I needed to roll the upper link mount to the rear a few degrees so it didn't contact the motor mount.
I was able to get my trac bar and drag link perfectly aligned and within an inch or two of being the same length. I'm hoping I won't have any bump steer with this setup.
Full bump looks good. I could move my axle forward another inch if I wanted to, but I would have to get creative with the upper link mount.
My upper link mount was hitting my starter before I achieved full bump so I put a 15* bend in it. 1.75" DOM with a 1.5" DOM internal sleeve that runs almost the full lenght. I left the inner a little short so my tube inserts would fit.
5001craig
Awesome thread. I just tried to rate it and couldn't because I already rated it before. Lol
JSmall
JSmall
A little bling from Tom Wood's. 1310 CV with a 1350 slip yoke. 1310 CV until I can get an Atlas.
I'm finishing up the front. I have to weld in the strut mounts and then burn all the brackets in.
